Old 04-17-2017, 03:52 PM   #1
Boerne , Texas
Images: 18
Awning Tube Replacement Source
The Zip Dee awning is a 3" tube of 18 gauge galvanized steel on my AS. Mine is bent and creased near the center so it is unrecoverable. My local metal shop has 24ft lengths of 14 gauge tubing for $45! I need to check them out. The 14 gauge will be heavier by 0.7 lbs/ft not to mention getting the hardware to fit the inside diameter. I'm not sure if this could be a possible substitute? Has anyone tried this change.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 04-17-2017, 05:00 PM   #2
1976 31' Sovereign
Oswego , Illinois
Cool
I don't think weight would be factor. I would not do if hardware does not fit inside. Zip-dee sells all parts for replacement.
Old 04-18-2017, 03:54 AM   #3
Boerne , Texas
Images: 18
It will add about 14 lbs to it but it will be stronger. Price is the big kicker. $45 vs $700 just for the tube from Zip Dee.
James B.
Old 05-23-2017, 05:31 AM   #4
1994 30' Excella
Shelby , North Carolina
Did the metal shop 3" replacement "pipe" work with the slight thickness difference. Mine collapsed in the middle during a 3 inch monsoon downpour yesterday. I thought since it was only out a few feet I could leave it slopped and..... Well, if my IQ was three points lower I would have been a tomato.
So, Will the pipe be a fix or go to Zipdee??
Daguvanuh is offline   Reply With Quote
Old 05-28-2017, 04:57 AM   #5
1994 30' Excella
Here is the fix I am using. Went to local muffler shop and had a 2 foot section of 14ga muffler pipe welded in the collapsed area. Feels strong, not much added weight, and I rust proofed the weld seems and new metal in splice.
$60 is cost right now. Installing it tomorrow.
Old 05-29-2017, 04:58 AM   #6
Boerne , Texas
Images: 18
I was thinking of going that direction too. The local auto parts store has 10ft sections of 3 inch OD exhaust tubing for 50 bucks. I was going to weld them together to get the length I needed. Trouble is, the muffler shops wouldn't weld them for me because of the risk of getting the final product nice n straight. I guess I could throw a 10 ft piece in the center of the total length. That would give it more strength too.
What did you rust proof the tubing and welds with? O'reilley's autoparts sells an aluminized tubing. I expect that is a coating as a protectant from exhaust acids etc and should, in itself, be rust inhibiting.
James B.
Old 05-29-2017, 05:16 AM   #7
1994 30' Excella
Rust proofed with some Krylon rust preventing paint my wife had for a steel swing on the patio of our home. It still will have exposure on the inside of the pipe but the splice itself is aluminized metal so those weld seams on the inside is the "time" exposure most critical.
Old 05-29-2017, 05:19 AM   #8
1994 30' Excella
PHP Code:
[PHP
[/PHP]here it is...
Old 06-09-2017, 06:00 AM   #9
GuitarmanFL's Avatar
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
I've considered this option as well. In reality, our Sip Dee tubes are really just long fence posts...
The Shifty Drifter.
2018: 7500 miles: FL to Co
2019: 7500 miles: FL to Co
GuitarmanFL is offline   Reply With Quote
Old 06-12-2017, 04:17 AM   #10
Boerne , Texas
Images: 18
I just replaced the entire length of awning with a 3" exhaust tubing. Turned out great but it wouldn't wind up. I had to give it 12 extra turns of tension on the spring to get it to pull itself. Weight of the 14G exhaust tubing setup is 62 lbs vs the 18G original tubing at 34 lbs. I'll try this for a while and see if I recommend just removing the buckled portion and adding a section of heavier tubing in it's place.
James B.
Old 06-12-2017, 04:26 AM   #11
1972 27' Overlander
Denver , North Carolina
I ordered one from zip Dee when mine was bent due to a bonehead maneuver on my part. Replaced it myself , I had to get real creative to do that job. But now and very careful about how, when and where I deploy my awning.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 06-06-2019, 08:45 PM   #12
Boerne , Texas
Images: 18
I had problems with the weight of the exhaust tube and it wouldn't roll up very well. I replaced bent section in the original tube and reinstalled it. Happier with the roll up now, although it took extra tension to make it work.
James B.
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
My awning tube is bent- question . . . Splitrock Our Community 13 07-17-2010 04:21 PM
New roller tube for old Carefree awning maccamper Awnings 7 06-09-2009 05:49 PM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
