Old 12-27-2016, 01:06 PM   #1
1974 29' Ambassador
Columbus , 43220
Awning Troubles
My Zipdee awning needs help! The cloth has separated from the aluminum accordion cover in two areas about a foot long each. How can I reattach it?
tumbleweeds is offline   Reply With Quote
Old 12-27-2016, 01:52 PM   #2
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Suggest you call Zip Dee.
Mike
Caffeinated is offline   Reply With Quote
Old 12-27-2016, 03:01 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Awnings By Zip Dee
96 Crossen Ave
Elk Grove Village IL 60007
Telephone: 847-437-0980
FAX: 847-437-7064
E-mail: info@zipdeeinc.com
MICHAEL
Old 12-27-2016, 04:43 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
If you do contact ZipDee as others have suggested, pleased do let us know what is suggested, and how you make out - we never know when we could have the same problem!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-27-2016, 05:02 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I would guess the slate is a little wide in those two spots. The best way to fix it is to mark the spot on the slat, take the fabric off, slide it back in the slat, and use a rubber mallet to gently peck the slat's gap closed a little....The only way to do this is to take the fabric and last slat off the the trailer....I have had my fabric off because I had to get the rotten seams restitched. It was not hard. Zip Dee had the instructions on their website, I believe.
CRH is offline   Reply With Quote
awning troubles poncho/cisco Awnings 3 11-09-2008 09:41 AM
Awning Troubles Alaska1966 Awnings 1 08-01-2007 11:51 AM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Water troubles... Sneakinup Fresh Water Systems 5 01-10-2004 09:54 PM
