Old 07-20-2023, 08:58 AM   #1
2020 30' Classic
Cullman , Alabama
Awning stuck in lock
Hi everyone, we're camping in our 2020 Classic 30' in Milton, FL (hot as hades). Last night, the awning retracted by itself while we were going to sleep. This morning, it says "locked" on the Czone and the App. I can't get it to unlock via pressing the two "tilt" buttons and it won't open or close. I checked fuses and breakers, and did a battery disconnect. Also searched the forums, youtube, and called Airstream Tech (which was a waste of time) with no results.
Any ideas for me? This is really impacting my "cigar time" under the awning. :-)
John
hartmanjt is offline   Reply With Quote
Old 07-20-2023, 11:05 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Probably the best place to call is Zip Dee. If it is a Zip Dee awning.
Old 07-22-2023, 08:28 PM   #3
2022 30' Classic
Lake Toxaway , North Carolina
Don’t have a solution for ya but ours (2022 30 RBQ) has been flaky as ###***#.
Had the whole unit replaced early on and have had multiple gas struts installed along with a new board that got wet when the dealer was washing the trailer 🤦🏻*♂️
Going back next week for yet another gas strut replacement. The “Relax” awning has been anything but “Relaxing “.
Good luck to ya!!!
Bskinner is offline   Reply With Quote
Old 07-23-2023, 10:17 AM   #4
2022 30' Classic
Cohoes , NY
Bummer. Any luck yet?
One item to check is the awning controller which is located under the sink. You have to pull out the bottom drawer and it should be sitting on the floor. Check all the wiring connections, as they are prone to coming loose.
Joe
'22 Classic 30 RBT
'24 F250 7.3L
BRN 17600
Joey Joe is offline   Reply With Quote
Old 07-23-2023, 12:36 PM   #5
Jim J
Jim J's Avatar
2014 30' Flying Cloud
In a Jam
Could something have caused the awning to jam when it was rolling up? Like a pine cone or a branch on top that did not fall off?
It may want to work but isn't able to overcome the extra pressure caused by the jam. My (manual) awning catch is very hard to release when awning is out of alignment.
If it rained the night before your awning rolled up, water weight on the awning may have bent the roller enough to jam it.
Jim J is offline   Reply With Quote
Old 08-20-2023, 01:08 PM   #6
2022 25' Globetrotter
Simonton , Texas
Any resolution of this?
My 2022 25FB Globetrotter is now having a similar problem with the Zip Dee awning. The last time I retracted it, it coned a little and seems to have jammed shut. Now it will not deploy.
Fuse good and the control board looks fine. Just stuck tight. Relax awning has been nothing but stress.
Kirk77476 is offline   Reply With Quote
Old 08-20-2023, 01:20 PM   #7
Lily&Me's Avatar
Normal , Illinois
I suspect some small something has fallen onto your awning and then jammed the mechanism as you rolled it up.
Mine has been stuck this way for a couple of years, for this reason.
I need to get someone on a ladder to remove debris, but just haven’t gotten to it.
Other than waiting years for whatever is in there to disintegrate, I think this is the only solution.
Maggie
Old 08-20-2023, 07:08 PM   #8
2019 30' International
Pennsylvania , Pennsylvania
I don't have C-zone, but my relax was actin up a couple weeks ago. I did find the main cable to my control board was loosey goosey. I unplugged that puppy, counted to 29, plugged it back in, and for now, I'm relaxed
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 08-23-2023, 11:01 AM   #9
2017 25' International
West Lake Hills , Texas
^This happened to us, too. Unplugged everything from the control board. Plugged everything back in. It worked.
Have you tried to open the awning using the emergency kit that has clamps for the battery? Polarity one way to open. Reverse polarity to close. Polarity being which clamp goes to which post (pos/neg) on the battery.
Also recommend you call Zip Dee. Talk to Randy if you can. He spent an hour with me on the phone to resolve a very tricky issue that even he had not encountered.
Fungus is online now   Reply With Quote
Door lock stuck Victor Stone Doors & Locks 14 01-14-2023 04:28 PM
Outdoor Shower Lock STUCK GoinStreamin Exterior Storage Compartments & Access Doors 14 05-27-2021 12:56 PM
Zip Dee Wheel Lock Stuck Kevio Awnings 27 09-06-2018 09:56 AM
Door Bolt lock stuck? tobutton General Repair Forum 15 08-26-2015 01:20 PM
Zip Dee Z-lock lever is stuck aname4me Awnings 4 03-17-2011 06:13 AM
