Old 07-26-2022, 07:44 PM   #21
1976 31' Sovereign
Oswego , Illinois
I use plastic 2 step folding stool to tighten wheels. When I tighten I squeeze both arms, takes up slack so can make tighter. The so called stick is junk only good to pull strap main awning, it can slip out of wheel making long scratch in clear coat
Old 07-26-2022, 07:51 PM   #22
dznf0g's Avatar
Oswego , Illinois
Yup, I agree.
-Rich-
Old 07-26-2022, 09:03 PM   #23
2010 25' FB Flying Cloud
Davenport , Iowa
I use the stick to LOOSEN the wheels, turn the awning lock and on the pull strap; to both open and close the awning. I also use to pull the pads under levelers and chocks. I use a stool to TIGHTEN the wheels on awning lock.
I store the stick on the handle inside the door; also shortened so it would fit.
mj
Airtandem is offline   Reply With Quote
Old 07-31-2022, 12:38 PM   #24
2019 25' Flying Cloud
Greeneville , Tennessee
Stool
Originally Posted by Hans627 View Post
Somewhere along the road I lost my awning stick. Perhaps I forgot it at a campsite. I would like to replace it with something better. Of course it is used to hook the loop on the awning to pull it down and also to disengage the little hook.
Has anyone come up with something better? Any ideas?
Thanks!
I use a collapsable stool that I got from Amazon. Sure is handier than the zip dee stick.
jimfa440 is offline   Reply With Quote
Old 07-31-2022, 03:37 PM   #25
2008 23' Safari SE
Pasco , Washington
I'm 5' 8" and am able to do the same on our 2008 23FB Safari.
ckronvall is offline   Reply With Quote
Old 07-31-2022, 03:53 PM   #26
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
I’m 5-11 life was good with the folding step stool then I go get the trailer lifted 3 inches. Not so go on the back wheel ok on the ft step
Life is a Highway is offline   Reply With Quote
Old 08-01-2022, 05:48 AM   #27
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Originally Posted by life is a highway View Post
iím 5-11 life was good with the folding step stool then i go get the trailer lifted 3 inches. Not so go on the back wheel ok on the ft step
lol!
Old 08-16-2022, 01:46 PM   #28
Hans627's Avatar
Tavares , Florida
I'm the OP on this thread and just wanted to thank everyone for their ideas.
I purchased a "boat hook" which will serve the purpose of hooking the awnings to pull them down, but also serve as a hook to pull things (and push) from (and into) the bed of the truck.
Should work very well and like that it is collapsible and has a nylon tip.
Again thanks!
ID:	421094   Click image for larger version
Tip of Awning Stick Hans627 Awnings 22 07-28-2019 06:13 PM
Dip Stick Bill Resseau Mechanics Corner - Engines, Transmission & More... 26 11-09-2010 04:08 PM
weatherstripping didn't stick Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 04-03-2005 11:49 AM
Stick-on-States Stefrobrts On The Road... 21 12-18-2003 02:02 PM
Dometic dip stick? Stinky Refrigerators 2 11-03-2003 07:22 PM
