Old 07-12-2015, 10:10 AM   #1
1988 32' Excella
Anderson , South Carolina
Awning spring
Just installed a new main awning spring, took me a couple of hours. Most of the time was spent trying to get the broken spring out of the roller tube. It would not just pull out, it was stuck pretty good. After taking a rod with a crook in it I managed to stretch it out with a lot of tension. Clamped vise grips to it an took a rubber mallet and tapped on the roller tube for a while. That didn't work so I stretched the spring out some more to put a lot of tension on it and began tapping the roller again and it shot out like a cannon. So lessen of the day is keep clear of the end of the tube when that thing comes out.
sl8er57 is offline   Reply With Quote
Old 07-12-2015, 01:02 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Excellent advice!!
Peace and Blessings..
Channing
WBCCI# 30676
Hensley Spring Plunger, Grease fitting spring bar retainer dznf0g Hitches, Couplers & Balls 2 08-29-2012 07:43 PM
ZipDee Awning Spring Stop Rivets Question 3blessed Awnings 0 06-16-2010 08:43 AM
Carefree Awning Spring adonh Awnings 2 02-27-2009 05:16 PM
Zip Dee awning spring unravels?????? letsgo Awnings 10 02-22-2009 07:20 AM
awning doesn't roll up, spring ? JohnTF Awnings 11 10-24-2007 09:53 AM
