06-12-2017, 11:18 AM
2015 22' FB Sport
West Halifax
, Vermont
Awning Set-up Problem
Hi there,
I'm not sure if there is a repair forum that would be a more appropriate place to post my question, but maybe someone here can help. I have a 2015 22FB Sport that I purchased new. Because of all sorts of unexpected events, I have yet to get out with it more than a few times but I'm hoping that will change! But that means that I'm still an AS newbie even though my AS is 2 years old.
As I went about spring maintenance, I discovered that there's a problem with the Zip-Dee awning. This is the model with curved end arms. When I roll out the awning, I find the rafter arms are about an inch too long to hook on the ends of the roller -- as if it should be possible to roll the awning out about another inch. If I extend the rafter arms to the first locking position (first "click"), they extend past the roller. If I hook them onto the roller just short of that first click, there is enough tension to hold the awning in place but I'm sure a stiff breeze would change that!
I used the AS so few times in the past two years, and often didn't need to set up the awning, that I can't be absolutely sure this is a new problem. As a newbie, it's possible I didn't notice the rafter arm wasn't clicking into place.
Is there an adjustment I can make to fix this, or do I need to get it back to the dealer? On a scale of 1 to 10 where 0 = utterly dangerous around workshop tools and 10 = the neighbor you call on for your DIY repairs, I'm a 3.
Thanks in advance!
Kelly
06-12-2017, 11:31 AM
2014 25' FB Flying Cloud
Des Peres
You should be able to push the awning out with one hand while placing the hook one arm on.
Do this one side at a time
06-12-2017, 11:38 AM
2006 16' International CCD
Steamboat Springs
I'll be interested in the responses. We have a similar issue with our newly acquired 2006 Bambi. It appears the rafter arms have spring tension where they will collapse the 1" in order to fit- but it took incredible force to make them do so. We had them unlocked, but in place, and then forced them out until there was a click into place. It took so much force, I'm wondering if I'm doing it right.
06-12-2017, 12:04 PM
1995 25' Excella
xxxxx
, xxxxxx
Watch the Zip Dee set up video online.
06-12-2017, 12:21 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
The hooks on the ends of the rafter arms are spring loaded.
One should pull the locking pin at allow the rafter to slide freely, then place the hook on the roller
Then grasp the rafter sleeve and push it out until it locks under spring tension on the roller. I would say with a bit of force, but don't over do it.
Watch this video....
Regards,
JD
Jeff & Cindy
06-12-2017, 12:24 PM
2022 27' Globetrotter
Asheville
You are probably trying to place them on the pin mid point instead of on the very end of the rollup bar that holds the fabric.
06-13-2017, 10:21 AM
2015 22' FB Sport
West Halifax
, Vermont
Jdalrymple, thanks for the YouTube link.
I see now that I have to hook the rafter arm on, and THEN pull until it clicks. Unfortunately, the person making the video says to use your weight to do this, because of how strong the spring is. He has a 100-lb weight and 10" height advantage over me, so he makes it look easy! I found that I can do it by getting on a ladder and throwing my weight away from the rafter but this seems a rather extreme measure.
I know this is a long shot, but is there any way to reduce the spring tension?
Thanks!
Kelly
06-13-2017, 05:52 PM
Central
, Mississippi
Click the arms on the roller axle and pull against the spring BEFORE you raise up the awning.
06-13-2017, 06:06 PM
2006 23' Safari SE
Biloxi
, Mississippi
I use a step stool to have enough leverage to fully extend the arms.
MICHAEL
06-13-2017, 07:28 PM
Jay
, Oklahoma
The spring tension is there to keep the awning taught in the wind and under the weight of any rain while allowing a little flex.
A a quick jerking action on the sleeve, instead of a slow strong push, works the best. Stand under the rafter and pretend you are stabbing someone with a spear.
Make sure you do this with the main arms at the lowest, most retracted position.
Regards,
JD
Jeff & Cindy
06-13-2017, 07:42 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
I do this EVERY TIME! I have a real mental block about it.
06-13-2017, 08:03 PM
2019 27' Globetrotter
Missouri Valley
, Iowa
Spray a shot of silicone on the spring / slide area at the end of the rafter arm. That will help a lot. Then use the "spearing" motion to tighten them after placed on the awning and before raising.
Dan
06-14-2017, 11:10 AM
2015 22' FB Sport
2018 27' Flying Cloud
2021 30RB Classic
Fredericksburg
I pull the hook rod (female) off the trailer rod (male) to clean all parts and silicone and operate the crap out of the spring mechanism and pull buttons twice a year. My wife can deploy the awning by herself to the first click with little effort.
