Old 04-11-2021, 04:01 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Awning screws pulled out from Argosy
100% my fault.
I got too close to a building and clipped it with the awning. The rear bracket screws pulled out. I attempt to simply screw back in but the holes are larger now in the Argosy. Can I just get larger screws too fix? It appears the screws were already as big as they could be. Looking for advice for for this idiot...I mean, asking for a friend.
Dan
Dan S is offline   Reply With Quote
Old 04-11-2021, 06:19 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Pictures would be helpful, but an option might be to install a "riv-nut" in the hole, and then fasten with an appropriately sized screw. A riv-nut is essentially a nut that installs like a pop rivet such that the nut ends up on the inside of the skin.
good luck!
Old 04-14-2021, 08:38 PM   #3
Dan S's Avatar
1975 Argosy 26
good luck!
Youíll have to zoom in. The screw holes can be seen and one of the screws to the right. Itís the best photo I could getClick image for larger version
ID:	393249Click image for larger version
Old 04-14-2021, 11:20 PM   #4
1972 25' Tradewind
St Clair County , Michigan
You'll need to buy a box of smaller holes.
TR Anderson is offline   Reply With Quote
Old 04-15-2021, 10:07 PM   #5
Belegedhel's Avatar
Houston , Texas
Doesn't look too torn up, you might be able to just go with a slightly larger screw, but the riv-nut recommendation might still work as well.
Old 04-16-2021, 04:09 AM   #6
Kevin245's Avatar
If the holes are too large I would consider going to rivnuts. I would use the aluminum bodied twist resistant type, designed for soft materials.
William C. Swinney
Overhead cabinet hinge screws pulled out Fipp Cabinets, Counter Tops & Furnishings 2 06-02-2018 01:31 PM
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
Help I pulled the wires out of my 7pin conection to tow vehicle. AustinAir Towing, Tow Vehicles & Hitches 9 01-10-2009 05:24 PM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
