Old 10-02-2022, 07:46 PM   #1
2002 31' Classic
Georgetown , Texas
awning questions
We have a 2003 Classic. The main Awning has 2 aluminum supports (1 at the front and 1 at the back). These supports are build with 2 pieces of aluminum tubing where one piece slides inside the the tubing. I have a problem with the inserted piece getting stuck in the tubing (on both the front and the back).
It appears to be oxidizing.
Is there any thing i use to remedy this what will not damage the aluminum tubing?
Bill G-Town is offline   Reply With Quote
Old 10-02-2022, 08:08 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I'd buff the inner arm with a Scotch-Brite pad and lube with silicone or Dri-Slide.
CRH is offline   Reply With Quote
Old 10-02-2022, 08:20 PM   #3
2020 23' Flying Cloud
2019 22' Sport
Sebastian , Florida
At the risk of boring you with a chemistry lesson, yes, aluminum is highly prone to oxidation, which is why it is never found in pure (elemental) form in nature. Aluminum metal is covered with a tough oxidized layer, chemically similar to garnet.
Problems occur when that layer is compromised by exposure to chlorides, caustic, or mercury, for example.
Most lubricants will not be an issue once you deal with the ongoing chemical attack.
Can you safely disassemble the arm, clean the contact areas well (outside and inside surfaces, maybe Walbernize) and then apply a conventional hydrocarbon or silicone lubricant? I think the key is cleaning off whatever is attacking the metal.
Good luck!
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 10-02-2022, 10:28 PM   #4
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Aluminum oxide, Al2 O3, is the same formula as Corundum (think Ruby and Sapphire). Hardness of 9. So you're sliding two sticks of Corundum against each other.
Aluminum will oxide very quickly after the oxide is carved off, so you're always going to be dealing with the oxide.
Lubricate to make those Ruby bearings slide across each other. Get them straight first.
The fight now will be who likes to use what lubricant on their Rubys.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 10-03-2022, 05:22 AM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Many time it seems that the problem extending the main support arms for a manual Zip Dee has more to do with how and where you're actually pushing than the amount of lubricant involved. My awning has the helper handles on the arms, allowing me to push them up in a straight line.
But, this only works if I stand facing away from the trailer and push them up. Doing this puts my arm in a line parallel to the awning arm and the lift is almost friction free. If I stand facing the trailer and try to pull the helper handles, the force is going up but at a slight angle away from the arm. This causes the upper portion of the arm to bind against the surrounding lower portion, making it very difficult to extend no matter how much lubricant is applied or how clean the parts are.
Here's a link to the helper handles, with a picture of a guy standing like I'm describing pushing away from the trailer. It seems quite minor on first glance, but if you turn and face the other way it just doesn't work as well.
https://awningsbyzipdee.com/products/lift-handles/
If you're having trouble extending the main arms after cleaning and lubricating, I'd suggest having someone watch while you do it to see if your line of force is parallel to the arm or at an angle away from it. And, if you don't have the helper handles get them - they make extending the arms much easier.
Richard
11018
richard5933 is offline   Reply With Quote
Old 10-03-2022, 05:54 AM   #6
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
awning questions
++ Richard 5933 , I found this video on YouTube helpful. At a point in time I thought my awning just didn’t look right when deployed. Not wanting to dislodge the awning arm I gave Zipdee a call and asked how many position hole stops were on the support arm, the tech checked and reported back that there were 4 hole stops. I was only deploying to #3. Hope that tidbit helps someone.
https://youtu.be/fLsKflCqhkY
Silvr_Bullet is offline   Reply With Quote
Old 10-03-2022, 08:06 AM   #7
1994 25' Excella
Yup - I was afraid to go past the third hole at first. First time I tried going to a fourth hole I made sure to do it on the end without the spring. Now I typically open the door end to the fourth hole and the other end to the third to allow drainage in case the sky opens up.
Richard
11018
Old 10-03-2022, 08:25 AM   #8
2022 25' Flying Cloud
Hayden , Idaho
Yes, we were told by our dealer:
“Go four over the door.”
MFFJC is offline   Reply With Quote
Old 10-03-2022, 08:42 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have also always gone to the fourth hole over the door and the third on the other end. We have to use the fourth on the door end or the top of the door scrapes the awning. If you use the fourth hole on both ends and it rains the awning will hold enough water that you may not be able to open the door.
We have always used spray aluminum lubricant on the sliding arms of the awning. This has always worked for us in preventing any type of corrosion and it keeps the arms moving smoothly. As soon as we detect any hesitation in the arm movement, we use the lubricant.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
Old 10-03-2022, 09:13 AM   #10
2007 16' International CCD
Somewhere , Colorado
We had similar problems with our 2007 awning, even after cleaning and lubricating. Turns out in our case the primary problem was that the two sections of tubing were not aligned straight and were binding. The solution was to press inward slightly while operating.
field & stream is offline   Reply With Quote
Old 10-03-2022, 09:15 AM   #11
1976 31' Sovereign
Oswego , Illinois
To stop scraping awning over door install roller at top edge of door, awning will glide not scrape causing wear. Zip-dee sells roller not exp. & easy to install, other sellers also have them.
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 03:37 PM
Awning questions for 1966 Overlander draftwomyn21 Awnings 7 05-10-2006 02:12 PM
ZIP DEE awning questions jmac Awnings 22 03-04-2005 12:26 AM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 08:23 PM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 04:07 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
