Old 09-01-2017, 08:04 AM   #1
la nomade's Avatar
2018 22' Sport
stanfordville , New York
Awning question
after a heavy rain,when i pull down the awning,it has some water running down ,looks like it was trapped in there ..always obove the sink window...i went up the ladder to look at possible cracks ...can spot nothing wrong....have no idea as to where the water gets in....just started doing so this spring.....
any idea anyone????thanks
la nomade is offline   Reply With Quote
Old 09-01-2017, 08:19 AM   #2
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
Are you saying water is running into your trailer above the kitchen window?
Airstreamin' dreamin'.
Follow our blog! https://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 09-01-2017, 08:38 AM   #3
Mollysdad's Avatar
I'd guess the awning roller sagged at the center and so that's the low point. Awnings aren't water proof.
Old 09-01-2017, 09:03 AM   #4
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
I think you're sayin that when ya pull out the awning after it rains, from the closed position, water comes out that had gotten trapped during the rain, right?
If so, I believe that is normal. At least it happens to me. Also, after a rain ya might notice that when ya lift or lower the jack to hitch up and have the trailer at an angle, trapped water will also run out of the awning. But I'm pretty sure that's normal too cause, like mollysdad said, the housing ain't waterproof.
TravlinMan is offline   Reply With Quote
Old 09-01-2017, 09:17 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Getting water into a closed awning seems to be a pretty normal thing. How or why it gets in - who knows.
Old 09-01-2017, 10:57 AM   #6
Traveler
TravlinMan's Avatar
Staunton , Virginia
Well if ya push on the plastic hinge thingee that becomes the housing while it's closed, you'll see right away how and why. It ain't watertight. Ain't even designed to be.
Old 09-01-2017, 12:58 PM   #7
la nomade's Avatar
2018 22' Sport
thanks,i will as of now think its normal ....and yes,it only happens when it rains really hard
Old 09-01-2017, 01:58 PM   #8
richw46's Avatar
Lexington , Kentucky
When I set up our awning I always put one side up higher than the other. You just pick a lower setting on the rafter arm. I usually set the rear rafter lower than the front. That way water doesn't accumulate in the awning, it just runs down the back and away from the AS.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
richw46 is online now   Reply With Quote
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Awning or no awning? 2wheelin Awnings 11 04-06-2010 05:38 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
