Old 03-20-2017, 07:20 AM   #1
1992 34' Limited
Sherwood , Arkansas
Images: 12
Awning Problems
Hi i went to open big awning in front, it opened ok ,followed vid to show me since my first time doing so the lower brackets with the claw type hook both bent at hook splitting where they fasten when i tryed to close it yes i unhooked them and put them back in retaining pins on arms or was that my mistake, should i have left them loose, also holding pin bent . when i retracted awning it wont line up to attach wheels. should i try to replace hooks myself and realign or should i take it to dealer.
Highball is offline   Reply With Quote
Old 03-20-2017, 07:38 AM   #2
Central , Mississippi
Zipdee has revised the way the arms work over the years. If your '92 is like my '91, you should not clip the arms in place until after the awning is rolled up.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 03-20-2017, 08:47 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have seen an Airstream video in which the lower arms are left clipped in, IMHO, this can put a lot of torque on the arm and in my case bent the lower arms. Now, I unclip before and after deploying the awning.
Zip Dee Awning Problems lmcatee Awnings 4 01-08-2012 10:33 PM
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
Update on Problems Problems pjzuk General Motorhome Topics 4 09-04-2007 06:02 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
awning problems kooblekidz Airstream Motorhome Forums 2 08-30-2003 02:04 PM
