Old 09-20-2020, 02:07 PM   #1
2019 27' Globetrotter
Salt Lake City , Utah
Question Awning not working
I've got a 2019 Globetrotter that we bought new earlier this year. The awning worked without problem for many trips, and then suddenly, nothing. The controls do not seem to be getting any power. Even the fuse doesn't seem to be getting power. While snooping around for other reasons, I came across what appears to be a control panel underneath the sink (by the back door) that appears to be awning related. Additionally, there is a wire that seems to have become disconnected. Can someone confirm that this is awning related and that the brown wire that is loose should be connected and may be the source of my power issues?
The brown wire that is loose appears that it should be connected into the green plug just next to the white wire.
Thanks for any help. I realize that this issue is covered under warranty, but I'd like to learn as much about this trailer as possible for the future.
The panel is mounted "upside down", so I've rotated the first image.
ID:	379103   Click image for larger version
PPMo is offline   Reply With Quote
Old 09-20-2020, 02:22 PM   #2
2018 25' International
Slidell , Louisiana
You are correct the brown wire with black trace is +12V and should be connected. Before you do, confirm it has positive battery voltage on it relative to any metal trailer ground. Then reconnect and it should fly like a kite.
Edit, if you don't have one, you should buy a low cost medium quality multi-meter. One with an inductive loop to read single wire amperage is a plus. Don't spend a lot, $30-60 depending on the features will do it. Consider a battery load tester also that tests for cold cranking amps so you can accurately monitor battery condition. Or if you have wet cells with caps to add water, just get an hydrometer.
Brian
Old 09-21-2020, 11:08 AM   #3
Thanks for the help. I reconnected the wire and the panel lit up like a Christmas tree. Awning is back to working like normal now.
Old 09-21-2020, 11:39 AM   #4
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi PPMo,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Awning not working cbg indiana Sprinter and B-van Forum 1 04-03-2016 10:48 AM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 01:21 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
