Old 02-20-2020, 05:28 PM   #1
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Awning hook lock getting loose
My 2019 Flying Cloud ZipDee awning has a hook lock that you rotate in place with the long awning tool.
The attachment point of the rotating hook to the awning shell is getting loose - I cannot tell if this is a rivet or threaded connection, but I need to do something before I lose it.
Advice?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 02-20-2020, 05:35 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It should be a screw and a drop or two of loctite will take care of it.
Richard
Old 02-20-2020, 06:58 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you ever have to buy a replacement travel latch kit, there is a tiny tube of Loctite in the kit.
Old 02-20-2020, 08:59 PM   #4
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
Mine did fall off. It is a counter sunk allen head screw on the back. Loctite will do the trick if the threads in the hook are still good. Mine had wallowed out so dealer gave a new hook kit. I also found street side window awing hook loose and added loctite. No issues since.
StuartsDad is offline   Reply With Quote
Old 02-21-2020, 09:15 AM   #5
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
What they said! We lost the original on a trip, and they sent me a new one. When we were at the factory, they said it is common problem. They installed a new one and did put the locktite on. No problems since that visit in October. It stays pretty tight when unlocking or locking. Good fix.
2017 28' Twin Flying Cloud
Old 02-21-2020, 09:47 AM   #6
Springville , Alabama
Yes, mine fell off and I replaced it with new one and Loctite.... seemed like it was 15 bucks or so for it. Unscrew it and add Loctite, should be fine.
driftwood1 is offline   Reply With Quote
Old 02-21-2020, 10:01 AM   #7
1976 31' Sovereign
Oswego , Illinois
When using loctite use green as it's self wicking also easier to remove fasteners as red very hard to remove bolts etc. some time have to use heat. Red is more permanent bond than green. IMO do not use red on awning hook, green on hook will not come loose/
Old 02-21-2020, 12:37 PM   #8
2020 25' Globetrotter
Full-timer from , North Carolina
If you are doing the repair yourself, be thoughtful about how much you tighten the screw after applying the LocTite. Try to find the sweet spot that is snug, but still allows the latch to swivel freely.
dumbclub is offline   Reply With Quote
Old 02-21-2020, 12:57 PM   #9
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
What nobody has said is that you need to pull out the awning about a foot and block it there with a cushion or something so you can reach the screw.
Antique Pedaler is offline   Reply With Quote
Old 02-21-2020, 01:29 PM   #10
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
we probably forgot to mention this. It is so simple that we just forgot about it. If it was difficult, we will surely remember this well.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 02-21-2020, 03:47 PM   #11
2017 27' Flying Cloud
Brookfield , New Hampshire
I could see the screw backing out. What I ended up doing was put the awning out all the way but in the down position. I then reached up with the awning pole and caught the hook so it could not turn. My wife was under the awning with a Philips head screw driver and tightened it. Turned out to be easy. We did use loctite.
Larry
devilsbox is offline   Reply With Quote
Old 02-21-2020, 04:52 PM   #12
Halford1's Avatar
Make sure that the Loctite LockThreat does NOT touch anything else than the screw in the hook. Do not put too much but a few drops would do just fine. Someday you might have to remove the hook so if too much Loctitle is in the hook, it may stay forever. Its gonna be hard to use torch to heat the screw in the hook cause its so close to the aluminum panel. A few drops will do. If you accidentally put too much, just stop and clean out the screw and do a do-over with a few drops.
I applied a few drops in one of the hook that had been loose and did the other hook as preventive measure.
Old 02-26-2020, 09:32 AM   #13
Mollysdad's Avatar
Mine came loose too. I decided to put a small nylon spacer in there to help align the hook with the catch. Then Locktite the screw.
At first I thought it was a two person job, but as reported, if you just pull the awning out a foot, you can reach both sides.
BTW, Locktite comes in various strengths. Use the blue. (Which inexplicably comes in a red tube)
It can be removed.
Old 02-26-2020, 09:39 AM   #14
2016 30' Classic
Houston , Texas
Thanks for the recommendation to use Locktite 'green' versus 'red' - I wouldn't have known the difference regarding this specific application.
dhroberts is offline   Reply With Quote
Old 02-26-2020, 10:43 AM   #15
1976 31' Sovereign
Oswego , Illinois
[QUOTE=Mollysdad;2335678]Mine came loose too. I decided to put a small nylon spacer in there to help align the hook with the catch. Then Locktite the screw.
It can be removed.[/QUOTE Locktite has changed colors of tubes of red and blue. Reversed from when I last pur. It does not go bad after time as I still have & use red in red tube. Did not no of change of colors as have plenty left [all colors] that was given to me when racing.
Old 02-26-2020, 10:51 AM   #16
waninae39's Avatar
2017 22' Sport
NCR , Ontario
our fell off also.
As sent us a free placement as they DO NOT use lock tite at the factory even though it comes with lock tite from the OEM
we used lock tite and it has not come loose
waninae39 is offline   Reply With Quote
Old 02-26-2020, 11:45 AM   #17
2018 30' Classic
Jacksonville , Florida
I use clear fingernail polish instead of locktight. It has a nice little brush and is easier to put on. They sell it at just about any drug store.
Overstreet is offline   Reply With Quote
Old 07-31-2020, 03:26 PM   #18
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
My awning hook just fell off this morning. I'm camping and will be traveling tomorrow. I don't have lock tight with me (make note to self to add it to my tool kit).
If the awning wheels are tight is there any risk of traveling without the hook in place? What is the purpose of the hook anyhow?
Thanks!
Old 07-31-2020, 03:39 PM   #19
VeloBuckeye's Avatar
2018 27' Flying Cloud
Easton , PA
FWIW, I've occasionally driven away without setting the hook lock on either side awning. Occasionally it unhooks on its own while driving. No issues experienced.
VeloBuckeye
2018 Flying Cloud 27FB - "The Shoe"
VeloBuckeye is offline   Reply With Quote
Old 08-01-2020, 09:51 AM   #20
gypsydad's Avatar
Thanks!
I had my awning come loose while towing some years back...saw it outside my mirror and horror feeling....pulled over and used duct tape to secure. On my currant 2017 model, I lost the hook/latch early on; AS mailed me a new one with the locktite tube. I installed and no more issues. Not a good feeling to see your awning opening while driving on the interstate at 65 or so!
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
Front door key hole getting loose AIR-Quarius Exterior Storage Compartments & Access Doors 1 11-10-2014 05:33 AM
Awning... Should lock side arm be loose? How to tighten? BessieB General Repair Forum 1 08-26-2014 02:17 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
