Old 08-01-2020, 10:45 AM   #21
Mollysdad's Avatar
As a fail safe, put a Velcro strap (or whatever you have) around the awning arms.
I never understood why Zip Dee put the latch in the back instead of the front. Seems like the front would be attacked by the wind first, peeling the cover back.
Old 08-04-2020, 06:02 PM   #22
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
The best way is to put Loctite Threadlocker on bolt then put the hook on the bolt. be careful. Mine is still there without any issues and it keeps awning from coming loose. I have two hooks.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 08-05-2020, 04:31 AM   #23
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Thanks for the suggestions.
I'm on a mission to get some Locktite.
Hans627 is online now   Reply With Quote
Old 08-05-2020, 09:06 AM   #24
1976 31' Sovereign
Oswego , Illinois
Another thing about loctite is use green, just put green on threads, it will wick in to nut, plus if have to remove will be easier than, as red is very hard to take apart
Old 08-05-2020, 09:46 AM   #25
Mollysdad's Avatar
Blue?
Old 08-05-2020, 02:17 PM   #26
Halford1's Avatar
I used Red one. I do not want the hook to come off. It works superbly
Old 08-06-2020, 08:34 AM   #27
1976 31' Sovereign
Oswego , Illinois
Follow up to my post #24 Green locktite is self wicking that means it will creep into nut on bolt when applied after nut is applied, plus nut can be removed easily no strain or heat to loosen. When we raced pro & I used a lot of dif. locktite, red if critical not to come loose green if take apart as stated no heat or strain. Locktite was given to us all colors so no worry of cost had all wanted.
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
Front door key hole getting loose AIR-Quarius Exterior Storage Compartments & Access Doors 1 11-10-2014 05:33 AM
Awning... Should lock side arm be loose? How to tighten? BessieB General Repair Forum 1 08-26-2014 02:17 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
