Old 07-27-2020, 10:54 PM   #1
2017 19' International
Bloomington , Minnesota
Send a message via AIM to SAT Bloom MN
Automatic Patio Awning ( Awnings by ZIP DEE)
My awning on my 2017 International Serenity does not extend properly. The front end starts to extend but the back needs a little nudge to start moving.
they continue together until all the fabric has been extended. The interior arms
do not extend at all. The tilt does not work on either end. The door will not open because the awning is to low. Please give me ideas on how to fix my problem.
SAT Bloom MN is offline   Reply With Quote
Old 07-28-2020, 06:54 AM   #2
2018 27' Globetrotter
Elbert , CO
It sounds like your main arms aren't extending properly. We had a similar problem with ours until I gave both main arms a shot of white lithium grease. After you do that, just keep repeating the extend/retract cycle to distribute the grease along the gears and see if your awning goes out any farther with each try. It may take more than one shot of grease before you get repeat successes.
djb75 is offline   Reply With Quote
Zip Dee 12v Relax Patio Awning Fabric Replacement Instructions rewillia General Repair Forum 2 04-04-2020 01:24 PM
Zip dee automatic awnings JimGaskill 2011 - 2015 International 1 03-14-2015 06:59 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Zip dee automatic awning Nomad, 2nd Awnings 9 07-20-2013 11:32 AM
Zip Dee Patio Awning Stuck open ac4xe Awnings 3 05-08-2010 02:46 PM
