Old 09-17-2024, 10:28 AM   #1
Colorado Springs , Colorado
Argosy awning support arm bracket separation
Hello friends. I'm prepping my 1976 Argosy for painting and found this little (I hope) issue. The rivet on the bottom bracket the awning arm has popped out. I do full-time in it and I have been camped in a hot and sunny field lately, so I have been using the awning a fair amount. (I do strap it down with rubber truck ties if it's deployed, and if there's wind in the forecast I pull it in.)
The bracket appears to be attached with two large screws and I believe a buck rivet. Any chance there's a simple fix for this?
Thanks!
ID:	447423   Click image for larger version
Argosynaut is offline   Reply With Quote
Old 09-17-2024, 12:47 PM   #2
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
Thanks!
Usually (in my experience), the bottom awning brackets are riveted/screwed into the lower c channel. There's more meat there for attachment. I looks to me like yours is installed somewhat above that area.
Regardless, screwing high tension/force things into thin aluminum (even if it is aircraft aluminum), such as awning brackets/arms, is a recipe for eventual failure.
If it were me, I would cut an access hole in the interior skin (behind where the awning bracket attaches.) I would then cut and add thicker aluminum reinforcement plates and through-bolt the bracket on with stainless steel bolts and locknuts. I would then patch the interior skin hole with a bigger sheet of aluminum and rivet that on and paint to suit.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 09-17-2024, 03:02 PM   #3
Thanks for the input. It definitely doesn't look like a structurally sound part of the trailer it's attached to! This sounds like a pretty solid idea.
Old 09-17-2024, 03:08 PM   #4
DKB_SATX's Avatar
Alamo Heights , Texas
Guessing from the vertical rivet line one side of the bracket sits on, this is right at a rib which will make getting a backing plate "just right" a little fiddly, but should be somewhat secure when done. It may have lasted about 48 years so far, after all! It MAY be younger than that, since it looks like it's a Zip Dee arm (my Argosy had a Carefree that was tough as nails, though kinda fiddly to deploy and furl.)
— David
Old 09-18-2024, 02:04 PM   #5
1964 17' Bambi II
1961 24' Tradewind
True, and a good observation. I would then make to thick/large aluminum "washers," each with a flat side to butt up against/straddle the rib and bolt through as described.
I had to put a reinforcement plate inside the wall on my '64 where the front rock guard arms attach. One side had ripped through the original exterior aluminum skin entirely.
ZipDee Relax Awning Support Arm repair dedekp91 General Repair Forum 1 05-11-2022 10:37 AM
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 09:47 AM
Awning arm mounting bracket. Remount ??S tevake Classic Motorhomes 8 05-21-2014 07:11 AM
Zip dee awning support arm CMSmith Our Community 3 08-09-2012 09:35 PM
Broken Shock Bracket on Lower Control Arm Auretrvr Mechanics Corner - Engines, Transmission & More... 4 08-15-2009 06:15 AM
