Old 07-24-2020, 12:53 PM   #1
1968 30' Sovereign
New Richmond , Wisconsin
Are these usable or should I start fresh?
We are at the point in our project where it is time to consider the main awning. When we first got our Sovereign, I removed the awning brackets. the roller, and some of the attachments points. I cut the old awning off leaving about an inch of material attached to the railing at the top. The awning that was on there was in tatters - and I didn't really know any better (before I found Air Forums!). This looks to be a Carefree awning. The awning roller is 19' 7.5" NOT including the two end attachments (and those are 3" each).
I'm asking for advice. Do we use what we have (not even sure the awning arms work properly !!) and put a new awning on to the old roller? I'm not sure what the process would be - or the level of difficulty. Are there parts available if an arm is missing something?
OR - do we start fresh and have a brand new Carefree or Zipdee awning and parts installed. I am guessing about $2500 to go brand new - and that's the sticking point. If I can save a substantial amount of money retrofitting...
Thank you for any comments, advice, etc!
ID:	373831   Click image for larger version
ID:	373834   Click image for larger version
cheetah1 is offline   Reply With Quote
Old 07-24-2020, 12:57 PM   #2
dznf0g's Avatar
2007 30' Classic
Oswego , Illinois
I'd what you got. Order the material, clean and inspect every part. I'd take this opportunity to install a new roller spring, considering its age.
-Rich-
Old 07-24-2020, 01:00 PM   #3
"Cloudsplitter"
2003 25' Classic
X2
Sunbrella to the rescue.
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 14 01-20-2023 04:44 PM
Replace? Re-upholster? How to get a gaucho to be usable? andreasduess General Interior Topics 4 06-16-2013 09:04 PM
Lightest weight usable oven/stove? HHaase Stoves, Ovens & Microwaves 4 10-02-2011 10:56 AM
Laz the going to be usable AIRSTREAM Peachtastic General Repair Forum 0 09-18-2011 10:40 PM
are these axles still usable ? AxelBruijnis Axles 6 06-22-2009 10:30 AM
