Old 01-01-2025, 09:27 PM   #1
Jum
Jum's Avatar
1975 Argosy 26
Louisville , Kentucky
Adding awning to Argosy - pull out or patio style?
Our 26ft Argosy does not have an awning and we're wanting to add one.
A new Zip Dee is ~$3500 shipped, plus either I install or get it installed for extra. A patio style from Marti's or Shelley's is under $1000.
I like the open-ness of a patio style as you don't have to walk around the awning arms but takes a lot more setup. You have to store it while traveling vs a Zip Dee being on the trailer.
Any feedback?
Resale value isn't a factor - we bought the trailer for $10,500 and have put another $13,000 in it plus I'm currently doing an 800W/560ah solar/lithium setup also so we're already beyond what it could sell for but are building it out for our needs.
Here are pics of each style.
ID:	449832   Click image for larger version
Jum is offline   Reply With Quote
Old 01-01-2025, 11:15 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 198
RE: Awning for Vintage First Generation Argosy Travel Trailer
Greetings Jum!
My suggestion would be to definitely consider the convenience of the ZipDee. I have had rigs with the old-fashioned rope and pole awnings as well as my 1964 Overlander that I opted for the ZipDee.
I travel solo, and a rope and pole awning just became too much of a problem for setup on a regular basis, particularly for a longer trailer like the Overlander (26-foot). True, the ZipDee is an expense, but with the weather guard cover that protects the fabric from UV exposure when the trailer is in storage, the awning fabric lasts a very long time. With regular care as outlined by ZipDee that awning continues to look and function like new for years. The one that I had installed on my Overlander is now over 20 years old. It still looks and operates just as it did when it was new. I can easily deploy the awning myself, as well as store and lock it for travel; but I know that I would no longer be able to fight a rope and pole awning of the size used on the Overlander.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 01-02-2025, 07:43 AM   #3
1966 22' Safari
Fredericksburg , Texas
Jim, as Kevin mentioned, a ZipDee would make more sense if you’re traveling alone. A rope and pole awning would take forever to set up alone. But, since my wife and I travel together, we prefer the rope and pull awning. My wife ordered the awning material and sewed the seams and grommets herself for both our trailers. We use adjustable paint poles from a box store. It takes us about 5 minutes to se up. For a rainy period we can adjust the awning for drainage. If we have wind our ropes have a spring and pulley on the end to allow awning bellowing without the stake pulling out. If you need pictures let me know. Bubba
Bubba L is online now   Reply With Quote
Old 01-16-2025, 11:30 AM   #4
Jum
Jum's Avatar
1975 Argosy 26
We went with a patio style from Marti's. She (Kelly) is/was running her winter sale and I couldn't pass it up since she had one premade in a pattern that my wife was all about.
Old 01-16-2025, 01:21 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I have a vintage style awning we have never setup yet. I'd like to see your spring and pulley setup.
Stephanie
Old 01-16-2025, 01:28 PM   #6
Jum
Jum's Avatar
1975 Argosy 26
Me too.
Old 01-16-2025, 04:13 PM   #7
1966 22' Safari
I’ll post some pictures of the spring and pulley used on the rope and pole awning shortly.
Old 01-16-2025, 05:55 PM   #8
1966 22' Safari
Spring and Pulley
This is the pulley and spring assembly. You can get everything at a box store. You will see a spike in the ground with a washer to keep the rope from slipping off the head of the spike. That small loop of rope is attached to the bottom of a spring that has a pulley on the other top end. The awning cord is threaded through the pulley and kept taunt by the wooden handle.
ID:	450204 Click image for larger version
The fiberglass awning poles are actually higher quality telescoping painters' poles and screwed onto the end is a paint roller with the roller assembly cut off leaving a spike to slip through the awning grommet.
ID:	450210 Click image for larger version
Here you see the pulley and spring in use. Normally the two end awning poles would not have been dropped as they are, but rains were forecasted, and this keeps water from pooling on top of the awning.
Hope this helps,
Old 01-16-2025, 06:01 PM   #9
Jum
Jum's Avatar
1975 Argosy 26
You sir, are a genius. I love the setup and use of everyday objects.
Old 01-16-2025, 06:09 PM   #10
1966 22' Safari
Thanks Jum. Just trying to build a better mouse trap that works for us.
Old 01-17-2025, 10:00 AM   #11
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
That is awesome, thanks!
Stephanie
How to make YOUR OWN Patio/Awning Enclosure escapeez Commercial Listings 8 08-17-2017 06:12 AM
Old Style Sofa Vs New Style settee Opinions Needed Jim Clark General Interior Topics 3 01-23-2013 03:53 PM
curbside patio awning joopkeizer Awnings 5 11-24-2007 09:58 AM
old style brake conversion to new style Justmeandshe Brakes & Brake Controllers 1 06-23-2007 06:16 PM
