Old 08-20-2019, 06:28 PM   #1
APB
APB's Avatar
1978 31' Sovereign
Escondido , California
'78 International awning clamp wheel bracket
The rear clamp wheel bracket on my Zip Dee awning worked loose and when I tightened it one of the screws stripped. It still holds a little but not nearly enough to call it secure. What is behind the Aluminum skin that the screw goes into? Two tightened but I was fearful of really torquing them down and one has the head broken off.
It felt like sheet metal when it stripped. Anyone had to deal with this problem?
APB
Bluegrass is flat picking good!
APB is offline   Reply With Quote
Awning Clamp Assembly airtime Awnings 5 06-20-2018 05:23 PM
Propane Tank Bracket/Clamp Regulator Miked1256 Airstream Classifieds 0 09-01-2014 08:12 PM
hose clamp connection leaking mnboy1960 Waste Systems, Tanks & Totes 13 10-07-2013 06:29 AM
Propane tank clamp/bracket Dan S All Argosy Trailers 7 07-17-2010 11:47 AM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
