Old 09-02-2020, 06:24 AM   #1
Spaggs's Avatar
GAINESVILLE , GA
28’ Awning “Wing Span?”
I’m trying to figure out what dimensions I need to use in building a pole barn. I would like to be able to deploy the awnings while in the pole barn for cleaning and airing out. Hope to purchase all optional awnings for a 28’ FC.
Thanks.
Spaggs is offline   Reply With Quote
Old 09-02-2020, 07:44 AM   #2
2014 25' Flying Cloud
Temple , Texas
At least 35 long, then how far does your awning extend? You probably need at least 25 wide. You are talking about a pretty large barn if its in your back yard.
2014 Flying Cloud 25FB
2018 Ram 2500; Diesel
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 09-02-2020, 12:54 PM   #3
Spaggs's Avatar
GAINESVILLE , GA
I was thinking like you in respect to the 35’ length. That would cover the open awnings on the ends. I thought by doubling the trailer width, that would work, but that might not be enough..
I’m blessed to have enough acreage that this project is only restricted by how much I want to pay.
I’ve got a good gravel base that’s sloped. So, I first have to figure what size and then how much money do I have to do this project. I’m thinking a pole barn on a concrete slab. That way, if I want to go fully enclosed down the road, I can add.
Old 09-06-2020, 11:20 AM   #4
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
San Antonio , Arkansas
We are currently camping with the awning package deployed on all sides of our 2018 27FB which is 1” longer than the 28’. I took my tape measure and measured the following.
The main awning extends 6’ horizontally beyond the center trim band.
The street side and rear awnings extend 2’ beyond the center trim band.
twbucksr is offline   Reply With Quote
Old 09-07-2020, 05:33 PM   #5
Spaggs's Avatar
GAINESVILLE , GA
Thanks for measurements. With that in mind, I think I’m going to go with a 18’ wide by 36’ pole barn. I would go slightly larger, but the previous property owner graded and graveled a parking spot with these same measurements. Looks like it is meant to be.
Rainy outside-keeping inside spic and span Piggy Bank Airstream Lifestyle 12 05-15-2018 06:21 PM
Electric heater life span.... mbnroberts On The Road... 7 05-06-2014 12:26 PM
Propane tank life span bkahler Mechanics Corner - Engines, Transmission & More... 9 10-21-2012 11:06 AM
Life span of a hitch fun2bethad Hitches, Couplers & Balls 4 03-03-2011 03:04 PM
coupler latch pin SPAN? (measurement please) Astroboy Hitches, Couplers & Balls 4 06-24-2010 10:11 PM
