Old 04-20-2021, 01:19 PM   #1
Hillsboro , Oregon
White splotches
Iíve just removed my clear coat with some Citristrip, which is great stuff! But Iíve still got some lighter colored splotches that donít seem to be related to the clear coat. They seem to be discolored spots. Anyone know what causes this or what to do about it?
Warden Brown is offline   Reply With Quote
Old 04-20-2021, 04:07 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Yep. It's where the clearcoat was damaged (or removed?) previous to your Citristripping (probably years ago!?) and the bare aluminum has oxidized. The 'whiter' areas have been exposed to the elements longer than the 'grayer' areas. Think of it like a peeling sunburn...
If you are planning on polishing, you will be able to remove those splotches during the polishing process. Otherwise, now that you've stripped the aluminum, the rest of the trailer will oxidize & 'catch-up' to the oxidation level of the splotches in 10-20 years and it's be less noticeable.
Good luck!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
LED Color correction with filters, from cold blue-white to warm-white Bob Blarney Lights - Interior & Exterior 0 05-29-2019 08:08 PM
Warm-white vs cold-white LED lights? aircampr Airstream Lifestyle 64 03-13-2015 04:31 PM
Question about white aluminum oxide deposits williamhenshall Ribs, Skins & Rivets 11 04-02-2008 12:44 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
