Old 06-25-2018, 01:20 PM   #1
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Using Airstream polishing tech for headlights?
My fellow campers...
Like many of you, I have a heavy investment in polishing gear and various forms of goo to keep my trailer looking nice. Has anyone used this stuff to buff out their TV headlights? What grades did you use?
SuzyHomemakr is offline   Reply With Quote
Old 06-25-2018, 02:04 PM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
What "stuff" are you referring too?
thewarden is offline   Reply With Quote
Old 06-26-2018, 09:19 AM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
It's a great idea. I've seen and read to use 800 grit then 1000 grit wet sanding. Then sprayed with a clear coat. They looked new. I don't see why medium to fine polish won't do the same.
Matt
rugjenkins is offline   Reply With Quote
Old 06-28-2018, 11:35 AM   #4
1972 29' Ambassador
I tried using F7, and it helped a lot. I think that the problem is trying not to polish the paint job and chrome around it. Headlamps should be removed, and probably gone over with fine sandpaper first as per above.
So my verdict is: go for it if you have lots of time, and it isn't hot out!
Old 07-19-2018, 04:49 PM   #5
1969 27' Overlander
Boise , Idaho
I use a wheel and buffing compound on an angle grinder. At the slowest speed, with a very soft wheel, using the finest compound (red or maybe white), and being extremely cautious, I can avoid melting the plastic of the headlight covers, and get a pretty good result. On a 2003 model, the plastic has actually yellowed, and there’s nothing to be done about that. ITs clear, but yellow, after polishing.
Jamespio is offline   Reply With Quote
Headlights for 2003 Airstream Landyacht alvinator Land Yacht/Legacy Motorhomes 9 07-04-2014 02:11 PM
Flashing headlights dead battery Chaplain Kent Mechanics Corner - Engines, Transmission & More... 13 05-24-2005 08:15 AM
Headlights 'ON' ignition switch buzzer Astrodokk Airstream Motorhome Forums 1 11-16-2003 05:11 PM
Best place to buy headlights? Astrodokk Airstream Motorhome Forums 11 11-12-2003 08:00 AM
'95 Classic Headlights: COMPONENT or SEALED? Griffin Mechanics Corner - Engines, Transmission & More... 1 02-07-2003 12:16 AM
