RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-26-2020, 09:38 AM   #1
Crested Butte , Colorado
TremPro 635 Melting?
I'm working on a 1974 international. I sealed the exterior with TremPro in the past. Now that I am trying to polish it; I am having major problems with the TremPro melting and smearing around on the metal. It turns black and leaves a mess that I cant get off. Sometimes it is so thick it forms a hard crust that will chip off.
I tried 1000 grit sand paper on a buffing wheel and it clears it off for about the first second of contact then the paper is contaminated and smears it all around again.
Goof off does not do anything.
Ideas?
Tiangong is offline   Reply With Quote
Old 11-26-2020, 11:07 PM   #2
2019 22' Sport
High River , Alberta
If you canít wipe it off with a solvent, the black may just be oxidized aluminum and you need to keep polishing.
AlbertF is offline   Reply With Quote
Trempro 635 TravisA Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 06-11-2019 12:49 PM
Rear End Gap - Sealing over Trempro 635 with Eternabond jami20 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 11-10-2015 10:30 AM
TremPro 635 vs. Loctite PL S-40 OffTheCouch Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-29-2015 12:14 PM
TremPro 635 -vs- OCI QUAD -vs- OCI H2U grndslm Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 05-19-2015 08:33 PM
Alternatives to Trempro-635 perryg114 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 12-12-2014 02:31 PM
