Old 09-19-2020, 03:50 PM   #1
2013 30' Flying Cloud
Central Point , Oregon
Removing oil
Hi!
I just completed a cross country trip from NY to California with my Flying Cloud. I was waylaid in Salt Lake City for a week and a half with truck issues. There was a massive oil leak that resulted in oil being sprayed on my trailer. Any ideas on how to best get it off without causing more problems?
Thanks!!!
CandaceG is offline   Reply With Quote
Old 09-19-2020, 04:06 PM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I have had to use this a couple of times on my AS, Zep Heavy Duty Citrus Degreaser. It did an excellent job of dissolving oil and grease on the front of the trailer and it did not appear to harm the clearcoat surface at all. Dilute per the instructions and spray on. I followed up with a good rinse without wiping. Then, another spray treatment, let it sit for a few minutes then washed with my regular car wash soap. It is water-soluble and cleaned very well along with the car wash soap. Of course, you will have to give it a good rinse, dry thoroughly followed up by the wax of your choice.
thewarden is offline   Reply With Quote
Old 09-19-2020, 04:07 PM   #3
2018 25' International
Slidell , Louisiana
Especially if it is grimy and thickened, WD-40 works nicely followed by car wash detergent. The bug and tar removers are similar variants of the WD-40 solvent.
Brian
Old 09-19-2020, 04:14 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
Then wash with Dawn...it's formulated for oily ducks.😂
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 08:34 PM
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
oil and trans fluids ALANSD Airstream Motorhome Forums 22 08-01-2002 02:47 AM
