Old 12-24-2020, 11:16 AM   #1
1965 24' Tradewind
San Diego , California
Removing Corrosion from Skins
Happy holidays to all. I'm wondering if there is a way to get the corrosion off in the attached pic. I've used Nuvite F9 to repair/remove scratches and gouges, etc. on the front end cap. Huge improvement, but can't get all the corrosion to come off that is between the AIRSTREAM name plate and skin, and the front window rain gutter and skin. Woulnd't be concerned if it was limited to just being underneath and could be hidden. Unfortunately, the corrosion migrated outward and is visible even with the name plate and gutter back in place. I noticed some of the corrosion under the name plate has been completely removed and now you can see the nasty pitting. But, at least it's shiny and looks a lot better than the black corrosion. Running my finger across the black corroded areas around the window gutter, I can tell that it is raised. This is after hours of polishing. I tried sanding with 2000G wet/dry paper in a spot that will be hidden. That brought the area down flat, but still some corrosion in the pitting. The sanding marks didn't come out after about 5 passes with F9, so I haven't continued with that method. Any ideas on how to improve this?
I'm considering "framing" the AIRSTREAM name plate with some alclad that will stick out about 1/2" or so from the nameplate border to hide the pitting around the perimeter. Also considering fabricating a new window rain gutter that will sit about 1/2" taller than the original, which would hide things.
Name:	Front End Cap Corrosion.jpg
65TW is offline   Reply With Quote
Old 12-24-2020, 11:28 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Not sure what grit sandpaper you used, but typically for spots like this we started gently with something about 4-600 grit, then worked our way up to 1-2000 grit wet-sandpaper before polishing with the Nuvite. the compound will not remove deep scratches alone.
Otherwise, framing it out as you described would work...
Good luck!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Should I use Corrosion X on brand new trailer to prevent corrosion ILOVESALLY General Repair Forum 33 06-29-2021 10:19 AM
External and Inner Skins have all kinds of corrosion.... Supergrafx77 Ribs, Skins & Rivets 35 03-20-2016 12:59 PM
Corrosion inside of exterior skins - anything to do? Airwave503 General Interior Topics 11 04-17-2015 09:44 PM
removing interior skins Debnw General Repair Forum 6 05-01-2012 06:26 AM
Removing Interior Skins Swanny General Interior Topics 5 07-20-2006 10:39 AM
