08-09-2017, 07:23 AM
1992 29' Excella
Virginia Beach
, Virginia
Polishing, what to do - what to do?
I've been stripping off my plasticoat and I'm nearly ready to begin polishing. http://www.airforums.com/forums/show....php?p=1983867
At this point I'm in the process of looking for the right tools, polishing products, etc. I'm pretty certain I'm going to use Jestco Products, but I've yet to decide for sure. Their method requires a much higher rpm polisher (3000 - 4000 rpm), which is really a repurposed grinder, but the claim is that it really reduces polishing time.
I've only spoken with one Streamer whose polished his AS, a 97 30' Excella and he also ended up using Nuvite and other things, but his AS was looking good. The main power tool he used was a Dewalt DWP849X 7-Inch/9-Inch Variable Speed Polisher. He's using a Cyclo for the final polish.
Some of the stuff I'm also wondering about are the following:
Should I remove all of the marker lights, and if so how do I keep from losing the wires inside the wall. *If memory serves it seems I went to replace one of the marker lights a few years ago and the damn wire was so short I chickened out and just replaced the lens. *
What about the belts (rub rails)? *I have one at the bottom and another at mid level. *They both consist of an aluminum track with a blue plastic / rubber stripe that slips into them. *I stripped the aluminum sides of these, as well, when I did the body. It did not seem to harm the blue flexible plastic inserts, but I can replace that part if need be. *
I'm wondering if I should attempt to remove the aluminum belt rails for polishing or at least the rubber stripes? *Has anyone else done this?
I know I've thrown a lot out here, but I'll appreciate any experience based advice I can get.
Pete
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
08-09-2017, 08:19 AM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Pete, I used Nuvite and would not change that on the next one, started with C using an old craftsman 7" grinder/polisher(I would update that though) and I might try a courser grade but it did cut the mill finish in a few applications. The Cyclo is a must to follow up with and I used C first followed by S for the final, the terry cloth needs to be used to get best results.
I removed the marker lights and taped over wires and holes, removed the badges and lettering and again taped over any holes, basically anything you can remove the easier and better the polish will end up.
I did leave the belt rails including the insert witch I replaced after everything was done, the extruded rail is anodized so when you bump it with the polisher it does not affect it much and I did not tape it but you could.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
08-09-2017, 11:25 AM
1992 29' Excella
Virginia Beach
, Virginia
My god, that looks great, Alan! Really amazing. So, when are you going to do the rest of it? [emoji14]
Seriously, I'd love to see some additional pics.
Thanks for taking time to answer questions and share your experience.
I guess I need to do some more reading on Nuvite.
The big draw for me toward Jestco, is the claim of less hours and the ability to see quickly areas that need additional attention. Of course, I have no personal experience to draw from. In my initial post, I was not totally clear, the Streamer who polished his 30' Excella, started with Jestco, but apparently, also used some Nuvite. Unfortunately, I did not question him enough on why he did that.
How many hours do you estimate you spent on polishing?
What would you say were your biggest surprises?
What would you do differently if doing it again? I've already learned several lessons on just the stripping.
When you polish the upper areas and the end caps what type of platform did you use. I'm 5'5", so I need ways of comfortably reaching and working on the high areas.
Speaking of high areas, I'm wondering if I should start high and work down, or does it matter?
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-09-2017, 03:11 PM
1991 25' Excella
Santa Ynez
Start at top and work down your cord will be rubbing the trailer and if you were at final polish it would leave marks. The rest of our trailer needs some more work but with summer temps and lots of sun you can't do much but get fried so will finish this fall/winter
08-09-2017, 04:36 PM
1991 25' Excella
Santa Ynez
Looks like Iphone pics are to blame for sideways as someone pointed out around here, only time I have posted from the phone and only pic that has been sideways.
Anyway I forgot to address the time issue and while I did not keep track since I was in a trance most of the time seeing only aluminum I would guess about 3 weeks 8-10 hrs a day by myself. Probably could do it in 2 weeks the next time since I have a better idea what I'm doing and would go straight to compounding with a new machine, not sure which but would center around what Nuvite says. As I said before too that I would try a heavier compound than C to begin with and that should speed up the process.
Will Rogers
Alan
08-09-2017, 07:58 PM
1992 29' Excella
Virginia Beach
, Virginia
Looking pretty sweet. Something to be proud of.
I totally get what you're saying about working in direct sunlight. I imagine it could fry you bad. I'm lucky to have a lot of shade here at our campsite. We're planning to remove the awnings tomorrow.
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-09-2017, 08:08 PM
1992 29' Excella
Virginia Beach
, Virginia
Gorgeous. Trance, or maybe just Alumatized. [emoji15]
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-10-2017, 11:48 AM
Black Diamond
08-10-2017, 12:40 PM
1972 Safari 23 ft
1972 23' Safari
naples
Polishing
I used nuvite and a buffpro buffer on my 1972 22 Safari and had great results considering I am a rookie.? The buffpro is great and doesn't produce swirls. Good luck
08-10-2017, 03:43 PM
1992 29' Excella
Virginia Beach
, Virginia
Originally Posted by Pygmypoacher
Pygmypoacher:
That last picture looks amazing. Very impressive. Curious, why did you switch methods.
Man, I just got rid of a full face respirator. What type / level of filtration did you use.
I've looked at Jestco. From what I'm seeing Zephyr looks very similar. Heard anything one way or the other regarding Jestco?
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-10-2017, 03:57 PM
Black Diamond
Originally Posted by Re-Pete
Pygmypoacher:
Regards,
Pete
Switched for the reasons mentioned plus I found myself taking multiple passes with the same polish grade when using the pads. Zephyr is only one pass per grade for me so far. Using three grades from fast cutting to fine polish. I'm not familiar with toes of masks/filtration or Jestco.
08-10-2017, 06:42 PM
1991 25' Excella
Santa Ynez
PigmyPoacher, that looks awesome! What do you think about the risk of over doing it with Zephyr? One of the benefits of Nuvite is you would have to really try to screw up to damage the skin but at the same time that does make it a slower process. Just curious what you think on that.
Pete you know we can never achieve that shine with our trailers, older ones using a different aluminum sheet grade, Alclad coating I think.
Will Rogers
Alan
08-10-2017, 08:37 PM
1977 25' Tradewind
Cibolo
Polishing My Airstream
Just had my 1977 Airstream polished for $550.00 and it looks great. They did it in one week and with 2 miles of my house. Yes, I'm a happy camper. If your AS need polishing give "1SHINE+", High Speed Polishing and Detailing a call at (210) 394-1868, 14287 I.H-10E, Schertz, TX and ask for Garland or give them a visit. Also, ask him to show you the video on his phone polishing as AS. What's in it for me. Zero but when some one does a good job or a bad job I'll pass it on and hope you do the same.
08-10-2017, 11:40 PM
1992 29' Excella
Virginia Beach
, Virginia
At your suggestion, I checked it out. Looks impressive, certainly something to keep in mind.
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-10-2017, 11:48 PM
1992 29' Excella
Virginia Beach
, Virginia
Noted,. I've taken a look at some Zephyr videos. Apparently, They recommend and provide a special wheel for each of the different stages and compounds. They never really mentioned the operating rpms, just said they were printed on the wheels. What rpms were you operating at, if you don't mind me asking?
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-10-2017, 11:54 PM
1992 29' Excella
Virginia Beach
, Virginia
Yeah, thanks, I am aware of that, but from what I've seen of the post alcad ASs that have been polished, I'll still be very happy and satisfied with the results. I just won't park next to Pigmypoacher. [emoji1]
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-11-2017, 12:01 AM
1992 29' Excella
Virginia Beach
, Virginia
That looks great. I can't possibly imagine how they did that for $550. You need to move and not leave a forwarding address in case they come to their senses! You got the deal of a lifetime.
Regards,
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-11-2017, 08:23 AM
Black Diamond
Regards,
Pete
The wheels vary slightly recommending big to exceed 3000 - 3200 rpm.
08-11-2017, 08:28 AM
Black Diamond
Personally I don't think one has more risk than the other. The tendency may be to overdo the pad since I don't think it cuts as well. The whole 'you'll cut yourself with a dull knife before you would with a sharp one'.
08-11-2017, 08:30 AM
Black Diamond
Either way you'll look funny...
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Polishing tips?
Rog0525 |
Cleaning, Stripping & Polishing |
10 |
04-30-2007 08:27 PM |
Polishing Again
davidz71 |
16 |
11-17-2005 05:40 PM |
Anyone else polishing?
64GT |
24 |
08-08-2002 09:19 AM |
Polishing questions
Charcigar |
0 |
02-27-2002 07:21 PM |
