From what I've read about aluminum aircraft maintenance, steel wool and steel brushes are not recommended. The reason not to use them is that small fragments of steel can become embedded in the aluminum, causing catalytic corrosion at the resulting contact points.
I did a quick google search and here's one source which discusses what to use and what not to use on aluminum surfaces. There are others, and they all say the same thing.
https://www.faa.gov/regulations_poli...83-30_Ch06.pdf
This is fairly lengthy, so to find the nuggets about steel wool do the following:
After the .pdf loads, hit the "control" and "f" keys together. In the search box that opens, type "wool". Use the up down arrows in the search box to visit each place in the document that "wool" appears.
