Old 09-08-2018, 01:25 PM   #1
1999 28' Excella
New Orleans , Louisiana
Painting the exterior panels for stove and hot water heater!
Our trailer has been polished so now we are doing some work to complete a fresh look. These 2 exterior panels need repainting. Do you have to use paint made for heat?
badkat is offline   Reply With Quote
Old 09-08-2018, 03:29 PM   #2
1966 22' Safari
Fredericksburg , Texas
Pictures would be good. If the outside is polished, am assuming the skin is more of a mat finish versus the mirror finish of 2024T3. There are silver paints in a rattle can that go up in heat protection. I would look at the auto supply places that sell high heat paints for manifolds and mufflers. I know Auto Zone has Dupli-Color that has a great matching Ford silver, but only goes up to 200 degrees. I guess it comes down to how hot it gets, what color you want, and if the color is exposed. Can you paint the inside of the cover with a 1200 degree high heat BBQ paint and polish the outside? Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 09-08-2018, 03:57 PM   #3
1999 28' Excella
[ATTACH]Click image for larger version
ID:	321883[/ATTACH]Guess the next thing is when the hot water heater is on after a while on propane to check how hot it is. Also with the stove when the oven is on.
Overlander hot water heater exterior body parts diggerdude Airstream Classifieds 0 10-16-2017 02:55 AM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot water heater exterior vent cover JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 11-03-2014 04:19 PM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
