03-14-2022, 04:06 PM
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I screwed up and scratched up the exterior
We were under siege at the farm. Thousands of Asian beetles were all over our trailer.
I ordered some traps from Amazon. Good reviews, etc.. Well I was in a big hurry, as usual and just didn’t think. I hung the two traps on the sides of the trailer. One was from the stove vent, the other from the strap for my street side awning. The traps did not catch a single Asian beetle. Instead a big wind came up and started swinging the traps back and forth. So I have perfect smiling scratches on both sides. On the last wash and wax I tried to just rub them out. They aren’t deep, as I saw what was happening and pulled them off pretty quickly. So far they seem impervious to a little elbow grease. I’ll attach a pic. Makes me sad, and a little embarrassed about looking at them.
Anyone have any potential solutions? You don’t have to reveal your boneheaded mistake in the process. I talked to the local dealer today. I was told there’s nothing they can do. I’m wondering if a ceramic coating might hide them. Don’t know.
Thx
Jeff
03-14-2022, 05:47 PM
Escape Pod II
2022 23' Flying Cloud
2018 22' Sport
Orange
If the scratches didn't get deeper than the clear coat, you can polish them out with a mild car polish made for clear coat. A buffer will be quicker, but be careful with it.
JEWare
03-15-2022, 06:33 AM
Wildwood
, Missouri
Thank you guys. I ordered some of the Meguiars scratch stuff. Will start very carefully.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
03-15-2022, 06:48 AM
2013 31' Classic
billings
, Montana
Leave it buffing it will just thin out the remaing clear coat
03-15-2022, 07:15 AM
2018 27' Globetrotter
Mooresville
, North Carolina
I know you don’t like the look of the scratches but I would think the main issue would filiform(?) arising if the clear coat has been scratched thru. To protect that area from that, Collin Hyde recommended a product called Sharkhide to me to control that issue. There are posts disputing if you can use it on your entire trailer but I think it would work in small areas where the clear coat is scratched and I have used it in small areas. It’s still early in the process for me to see if it controls the filiform.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
03-15-2022, 09:01 AM
2019 27' International
2014 25' International
Boulder City
, Nevada
Tow it to a Detail Shop and have them do the work. They will do it right. They will need to SEE IT... in person.
Call and ask if they will do it, first.
They can do it right. If you do it yourself... it may cost you more in the long run to have the Detail Shop fix what you did to fix... the problem. They will work with the panel to blend it all.
Human Bean
03-15-2022, 09:05 AM
Tampa
Thx
Jeff
I had a similar scratch when something fell alongside. Mine were worse than yours.
I used Simichrome.
Do not use power tools, instead, put a dab on a cloth like a handkerchief, and rub the scratch in a circular pattern. It takes hours, but it's strangely satisfying to see the scratches slowly disappear. You'll know when to quit.
03-15-2022, 09:46 AM
2012 23' FB International
Woodstock
, Ontario
Filliform is caused by differential metal contact...usually the Zamac type lights and bezels around openings reacting with aluminum.
The scratches if deep enough will lead to the aluminum corroding and losing its lustre.
I doubt the plastic traps have scratched through the clear-coat.
Polishing will reduce, if not eliminate the scratches. Other than that you have your first badge of experience on your trailer. Be happy it isn't a dent!!!!
JCW
03-15-2022, 10:38 AM
1966 17' Caravel
1972 21' Globetrotter
SW
, Missouri
Those traps will attract more beetles than you had before putting traps out.
03-15-2022, 02:51 PM
2019 30' International
Pennsylvania
, Pennsylvania
ScratchX from Meguiars is extremely mild stuff. You 'could' rub through the clear coat but you'd have to rub hard for a long, long time.
If you pull a fingernail across the marks you have there, and your fingernail does NOT catch a groove, then ScratchX will help considerably.
If you want, pick a scratch on your car, or your kid's car, or a lawn tractor, and try it out on one of those first, so you get the feel for the stuff.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
03-16-2022, 06:43 AM
Wildwood
, Missouri
I bought 6. Have yet to see a single lady bug/ Asian beetle in any of them. They are still piled up next to doors. We extended the awning a few weeks ago, and there were hundreds falling out.
2020 25GT FBT
03-16-2022, 06:45 AM
Wildwood
, Missouri
Going to give it a shot. No power tools. I’ve got plenty of scratches on my old FJ Cruiser (200,000+ miles) to practice on.
Thanks!
2020 25GT FBT
03-16-2022, 07:01 AM
KW
, Ontario
Some scratches that aren't too deep you can reduce or get out. But be careful. You can easily go through the clear coat. Worse case you'll need to have the panel re-cleared. Best not to have to go to this extent, but stuff happens.
03-16-2022, 07:39 AM
I used Simichrome.
I’ve only used simichrome to polish pipes on my motorbikes. It works absolute magic de-yellowing chrome pipes.
That’s cool it worked on the body panels of the AS because it’s recommended to be used only on uncoated metals.
03-16-2022, 08:28 AM
Tampa
Maybe it's because I only used a dab on a clean cloth.
I didn't cut through the clear coat or discolor it.
It took a few sessions.
I found Simichrome when I wanted to remove some fine scratches on a polished firearm. Took forever, but I was happy with the results.
It's about the consistency of toothpaste, and a dab might be 1/4" diameter. Get a stool and work one area at a time.
03-16-2022, 08:30 AM
Very nice. That’s the trick: slow and steady!
Good to know this stuff is a viable option because I always have a tube around.
03-16-2022, 12:55 PM
Mooresville
, North Carolina
JCW
It may be caused by differing metals but if I remember how Collin explained it to me it is where the metal is scratched or, has places where moisture penetrates under the clear coat. Once that happens it just keeps creeping under the clear coat of the adjacent aluminum.
He also said the aluminum is clear coated before it gets to Airstream. When the factory cuts the sheets there is no clear coat on the sides and these areas are prime for filiform to occur as moisture creeps in those edges and keeps expanding to other areas. It is also possible in the sharp bends in the aluminum at the front and rear end caps where the clear coat is stretched and may allow for moisture to get underneath the clear coat.
If any of these occur you may need to have new clear coat applied. Collin uses Sharkhide in these situations. A friend of mine just has his Airstream ceramic coated and this provides the same protection. It’s a little pricey but the results are amazing.
In your situation, if the clear coat is compromised just keep a good eye on it to monitor for filiform.
"Roadrunner"
03-16-2022, 05:21 PM
1988 32' Excella
Robbinsville
, New Jersey
JCW
No galvanic corrosion is caused by differential metal contact. As GOUSC said Filliform corrosion is when corrosion penetrates between surfaces, regardless of what started the initial corrosion. On Airstreams those surfaces would be aluminum and clear coat.
03-16-2022, 07:19 PM
2018 30' Flying Cloud
Springfield
, Ohio
I would use a decent random orbital polisher with a medium cutting polish and polish the side of the trailer to remove the damage. You'll be happy with the result and you can do it in your driveway with an investment of a couple of hundred dollars. Polishing your damage by hand would be a long, hard ordeal.
Use the links below to get an idea of what is involved.
https://www.airforums.com/forums/f44...es-160603.html
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
