Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 06-05-2010, 07:08 AM   #1
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
GOJO! First cut for heavy oxidation
So it's unconventional I know, but I have areas that are really heavily oxidized and while washing up last night I thought how gojo hand cleaner would work. WOW. First cut knocked the heavy oxidation down and then I followed with diamond brite. Works really well.
What I noticed is that Gojo aggragate breaks down under heavy scrubbing into a fine material. I tried using the dewalt polisher, but hand rubbing areas yielded the best results.
Passing it along for fun.
Mud
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 06-05-2010, 09:20 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I'm amazed at what "Diamond Brite" alone did to one of my propane tanks.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-05-2010, 09:30 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Never thought about using GoJo but it makes sense.
Aaron
WBCCI #XXXX AIR #2495
Old 06-05-2010, 09:50 AM   #4
pinktrailer's Avatar
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Mud
Sounds great! Please post a picture!!
pinktrailer is offline   Reply With Quote
Old 06-05-2010, 12:22 PM   #5
. , At Large
Did you use the "Original Formula" or the "Extra Crispy (aka pumice)" formula? The pumice will break down into some pretty fine particles.
Old 06-05-2010, 12:24 PM   #6
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
That`s great,cleanup should be a breeze. Dave
easyride is offline   Reply With Quote
Old 06-05-2010, 08:17 PM   #7
Ottawa , ON
Yeah, and your hands should be immaculately clean when you are done!
Old 06-06-2010, 05:59 AM   #8
1956 22' Caravanner
Still as dirty
Yesterday was fun compounding and I made some pretty good progress. A bit sore today.
As for Gojo, that turned out to be an interesting option for stubborn areas. I used it on the door and it cut the first layer down pretty easily. The only downfall is that it dries easier so you end up using more. No biggie.
I'll post some pictures of the door. It's nicely cleaned up now, still need to cyclo it still, but I need to pick up some cotton fabric first.
Here are some pictures of the door shot this morning. Overcast day here in New England, but the closeup picture you can see the oxidation line. The door was 2-3 times more oxidized than the rest of the body. The top and bottom were first cut with Gojo, followed by diamond brite with the dewalt polisher. Trying to get it in reasonable shape for the TAC birthday bash at Bakers.
ID:	104152   Click image for larger version
Old 06-06-2010, 06:06 AM   #9
1956 22' Caravanner
something else
Something else about gojo that is interesting, the trailer hadn't been polished in tens of years so pollen, dirt and so on have caked into areas. Gojo did a nice job of loosening this stuff up with a soft cloth. A couple times I barked that I was getting this stiff mud in the seams, but it was this other stuff that was catching the polish, and oxidation mud and holding onto it. first pass with Gojo helped reduce the crap, plus it smells good
Old 06-07-2010, 02:06 PM   #10
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
formula
Which one did you use?
bwaysteve is offline   Reply With Quote
Old 06-07-2010, 02:08 PM   #11
1956 22' Caravanner
Pumice
Used the extra crispy version
Old 06-22-2010, 01:52 AM   #12
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Great Idea!
I'm going to try it!
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Heavy Oxidation monocoque Cleaning, Stripping & Polishing 179 03-08-2016 07:33 AM
Does oxidation cause oxidation bmklawt Ribs, Skins & Rivets 9 02-09-2009 09:21 AM
Heavy Oxidation #2 cuyeda Cleaning, Stripping & Polishing 10 06-11-2008 04:31 PM
Oxidation ? wohtex Cleaning, Stripping & Polishing 3 04-14-2006 08:31 PM
Oxidation davthr Cleaning, Stripping & Polishing 0 02-09-2003 08:06 AM
