10-27-2019, 09:39 AM
#21
South East
, Michigan
I use both Aero and Meguiar's® Ultimate Waterless Wash & Wax. Aero is a bit lower in cost if you buy the gallon. I did a side by test and think Meguiar's does a marginally better job. So, if you run out of Aero, you can probably buy the Meguiar's at most auto and big box stores.
I do like the Aero mop.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
10-27-2019, 10:10 AM
#22
Spruce
, Michigan
Anything I can use to remove very fine scratches from the exterior?
10-27-2019, 10:20 AM
#23
2017 28' International
Jim Falls
, Wisconsin
Aero makes a polish it is like a rubbing compound that you can use to remove scratches an a car. Might just try a normal rubbing compound.
10-27-2019, 10:43 AM
#24
2016 27' International
Sherwood Park
, Alberta
I would not use a rubbing compound on light scratches as it is too abrasive, especially for the finish on an AS. A good quality polish may do the trick on light scratches, if not, a very light polishing compound. Meguiar's makes an excellent product called Ultimate Compound, which I have had very good success removing light scratches. A lot of combo cleaner waxes also remove light scratches. Walbernize works quite well in removing light scratches as well, and it is the product Air Stream recommends for the clear coat finish.
10-27-2019, 11:05 AM
#25
Elliot/Barbara
Airstream - Other
Fort Collins
Carniba Car Wax
I have been using Turtle Wax Carnuba for several years on my 2006 Safari 28 S/O and it works excellent. The last thing before I put it away for the winter is to pressure clean and then appluy the Carnuba wax.
Water beads off it all year long.
10-27-2019, 08:18 PM
#26
2016 27' Flying Cloud
Georgetown
Agree with All You State
I used Walbenizer on my AS in the past. It does a decent job, but it seems like there was always a residue. And to apply it and let dry takes a really long time. I was just searching the internet for something different and came across this product: Aero Cosmetic Wet or Waterless Car Wash and Wax. It works great.
1). It does a great job of cleaning! If you have a bunch of bugs in an area spray it on and leave it set for awhile. The bugs come off very easily with a rag.
2). It leaves a great shine as it cleans. In other words you don’t have to clean and then wax.
3). If there is heavy dirt on the AS (mud) then you have to spray wash that off. But after that just spray, rub with a damp rag, then wipe with a dry rag.
What is nice is you can clean and wax in one shot. Just use a spray bottle and a terry cloth. Highly recommend it.
Great for your car as well. And it will work on a variety of surfaces.
I've been using this product on every Airstream we have owned over the course of the last 10 years. In fact, on our camping trip last weekend I spent a couple hours cleaning/waxing our Airstream with it ... as always it looked fantastic. It's kind of you to share your experience and recommendations and it's through threads like yours that others learn about helpful products.
10-27-2019, 11:48 PM
#27
South East
, Michigan
Meguiar's M5032 Marine/RV One Step Cleaner Wax should do the job and leaves a good wax while you are at it. Advises that it removes light oxidation. Easy to apply and remove with a low cost buffer.
Al
10-28-2019, 12:12 AM
#28
Salem
, Oregon
Hi, I used a waterless cleaner on my cars for a while. What I didn't like was that if I did a normal wash job and dried it with a chamois, my chamois would turn black. I bought Walbarnize and decided to try it on my Lincoln; It was good for only a few weeks, so I never put it on my Airstream.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
