I noticed one of the gray head casting as Zip-Dee calls it is kinda floppy on one side. As-if the hole in the head casting is 1/16" wider than the end of the awning that fits in there.
Other side is fine.
Tightening does nothing as it wont compress it and only holds in place. All parts seem accounted for...
Front cast head is tight and rear is loose. It has been this way for years and hasn't been a problem.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
