Originally Posted by Lumatic
What did you use for the strip lighting around the ceiling vent?
I made the light with wood and lexan which I already had. The LED light strips are
LEDMOŽ SMD2835 600LEDs Warm White Led Strip from Amazon with this
dimmer, also from Amazon. I didn't buy joiners for the LED tape, just cut it and soldered at the corners. There is almost 10 m of light strip, so it's quite bright, as I was hoping it would be. The dimmer works great with it and the light has a nice warm tone. The dimmer is mounted to the ceiling aft of the light with a homemade wooden knob on it.
I used Grafix Dura-Lar as a diffuser.
