Old 03-03-2019, 07:23 AM   #1
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Wiring Opinion?
I'm almost done putting in all my windows and thinking about the next stage.
Any consensus on: Do you put the wiring in first and then insulate? Or insulate and then wire?
Or do you make that decision after you decide what type of insulation to put in.
If I remember correctly on my can the wires were first and the pink stuff second.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 03-03-2019, 08:39 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We wired, then insulated. We used the pink stuff. I don't think that would change if you were to use a different insulation. the wires need to run through the metal supports in the walls, not on top of them. At least, that's how our '72 was set up. I admit I don't know how a '56 would be...
Kay
Old 03-03-2019, 12:03 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Factory would be to wire first, tape to outer skin in between ribs to support, then insulate.
If you want an alternative; I ran aluminum 'conduit' (5/8" aluminum fuel line from Speedway) inside the walls so I could fish wire/do repairs without removing inner panels. It does require some inner wall modifications where the wire exits to tie into your breaker panel/batteries. There are still short runs of wire on the floor/inner walls. At each end of the tube I flared it so there were no sharp edges to damage the insulation.
Either way, any large guage wire has to be in place before insulation.
Name:	conduit inside wall.jpg
I notched the wall panels to extend the conduit down to the floor. (FYI I installed the inner panels inside the channel to direct any water leaks away from the sub-floor. Areas around the conduit will be sealed with alumiinum tape.)
Name:	conduit at floor exiting inner wall.jpg
At fixtures/recepticles the tubing stays inside the walls. Edges of the wall panel hole are deburred and covered with tape/crommets as needed.
Name:	Conduit at fixture.jpg
If wiring goes into a cabinet (kitchen above sink) I bent the end of the tube to extend past the wall.
Name:	conduit ending in cabinet.jpg
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 03-04-2019, 06:52 AM   #4
1956 22' Caravanner
Thanks everyone ...I really did not want to insulate right now anyway...LOL
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Your Opinion, Asking $ 22,500.00 DreamStream Trailer Values 10 03-01-2004 10:18 AM
Black Water Valve Opinion Deppdog Waste Systems, Tanks & Totes 4 09-11-2003 04:27 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
