Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-23-2018, 05:15 PM   #1
1972 29' Ambassador
Las Vegas , NM
Wire spring inside water line from fresh tank
I am restoring a 1972 29' airstream - the hose coming out of the fresh water tank to the pump appears original. When I removed the hose, there was a spring inside. Is this to protect kink in hose, or serving some function to disrupt the water flow heading to the pump? Got me stumped...
Frank
LVNM is offline   Reply With Quote
Old 04-23-2018, 05:20 PM   #2
2007 22' International CCD
Very common thing to prevent the pump from collapsing the flex hose under heavy suction--like an almost-empty tank.
Many old cars had a spring inside their lower radiator hose for that same reason. My old '59 Chevrolet Biscayne had one because the lower hose was relatively soft and flexible.
Old 04-24-2018, 07:52 AM   #3
1972 29' Ambassador
Las Vegas , NM
Thank you!
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 31 05-15-2022 10:25 PM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 07:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Suction line from fresh water tank Kmontier Plumbing - Systems & Fixtures 7 10-11-2015 10:40 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
