Sounds like a switching issue between the Wally and your TV. You're on the right track. I'm not familiar with your HDMI switch, but it may get power over cable and not have a separate plug. If you can see the switch, do you see any lights indicating it has power?
BTW, once you get it fixed, don't be scared in the middle of the night when it sounds like an animal crawling on your roof. It's just your dish playing games with you. I was woken up thinking that when my in-motion dish did that every once in a while.
Originally Posted by Island Girl
Thanks for your input.
I DO hear the satellite antenna turning on the roof when I turn it on.
All the power switches are on.
The Wally receiver does have a solid green light on. Since the Wally came with the unit, I'm ASSUMING it is set up properly on the Satellite Antenna. But that is something I will check.
I will try connecting a new HDMI to HDMI cable long enough to connect directly to the TV eternally and see if I get a signal. Then at least I know what the problem is and I will just have to find someone to install it behind the walls of the unit.....oy vey.
I will let you know.....thanks again for your input!!
