Old 06-08-2017, 02:32 PM   #1
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Why Shocks on a Torsion axle?
Trying to understand why install shocks on a torsion axle. My understanding is that torsion axles are designed to be shock free.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 06-08-2017, 02:50 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Simple answer: With a torsion setup, you get a very fixed amount of shock absorption (or damping). Adding a real shock to the mix lets you better control the rock and roll of the trailer.
Old 06-08-2017, 02:57 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The torsion axle replaces a metal leaf or coil spring with a rubber one, but it is still springy. The shock absorber is basically a motion dampener, thus it takes the "bounce" out of the system.
A torsion axle may be less bouncy than a metal spring, but the system can still benefit from additional dampening. If you look around on these forums, there are several threads debating whether a shock absorber makes any difference, and there are definitely some believers out there who can attest to the difference they see in handling with a functioning shock absorber in place.
good luck!
Old 06-08-2017, 03:04 PM   #4
Sag Harbor , New York
A lay non-expert comment -- probably unclear -- but here goes . . .
Shock absorbers and torsion axles perform different functions.
Shock absorbers dampen according to the rate of acceleration of the moving part, the trailing arm of the axle/wheel assembly. If it moves very slowly the shock absorbers will not dampen the action much. Quick movement gets dampened.
The torsion axles are just like regular springs, in that they resist motion in a linear fashion according to the distance of movement. The more the tire/wheel moves up from road force, the greater the resistance from the torsion axle (or spring in the normal set up). It really does not matter how quickly (acceleration) the motion occurs.
If the road action results in fast motion, the shock absorber kicks in to dampen the action, in addition to the axle's linear resistance.
Sorry -- this makes sense here!
Lay comment over . . .
PS -- Just noticed Post #3 by Belegedhel -- similar IMO.
Old 06-08-2017, 03:07 PM   #5
1956 22' Caravanner
Hi
Okay I understand that much (thanks). I guess the next part of the question is the benefit worth the extra fabrication and cost.
If you listen to the axle manufacture they say thats the reason you have the torsion axle.
Old 06-08-2017, 03:14 PM   #6
Originally Posted by islandtrader View Post
If you listen to the manufacture they say thats the reason you have the torsion axle .
It would be interesting to know where you saw this, as Airstream has not offered such an overview that I know of.
As I just posted, the torsion axles and the shock absorbers have different functions IMO, and our AS's benefit from having both.
A trailer without a torsion axle, or without shock absorbers, would probably not work all that well, under all real world road conditions, including off-road.
Old 06-08-2017, 03:20 PM   #7
1956 22' Caravanner
Sorry for the confusion ...axle manufacture and not Airstream.
Old 06-08-2017, 03:36 PM   #8
Thanks, I would still be surprised if an axle manufacturer said not to use shock absorbers. I see on other forums posts about adding shocks to torsion axle assemblies for off-road use -- FWIW.
PS -- Our FC20 has small shocks forward of the wheel assembly.
PS2 -- nice rebuild thread!
Old 06-08-2017, 03:56 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Actually Dexter does say that shocks are not needed with their axles and they manufacture them without the mounts. So I think at least one manufacturer does say that.
I would want shocks added to mine.
Bill M. is online now   Reply With Quote
Old 06-09-2017, 07:12 AM   #10
Half a Rivet Short
2022 Interstate 24X
Hi
Well, they *used* to make them that way. Our original (1930's vintage) trailer was set up with a conventional axle and no shocks. I never rode in the back. I'm sure it was quite a bumpy ride Needless to say, it was not an AS. It also did not have trailer brakes. That lead to it's retirement long long ago.
Old 06-09-2017, 07:16 AM   #11
Half a Rivet Short
2022 Interstate 24X
Hi
Matching shocks to a given vehicle is a bit complicated. You need to get things right for them to do you any good. Getting it wrong can damage things. You can use the "try it and see" method. That may involve buying quite a few shocks. If you are handy with mechanical analysis software (and have a few months to spare) you can get pretty close.
Old 06-11-2017, 07:47 AM   #12
1956 22' Caravanner
Hi
I tend to agree with you. I remembered when I was building street rods and trying to get the shock thing figured out. Even with the manufactured aka. Mustang II Heights suspensions...We had a lot of trial an error. For the time being I will stick with what I have.
However let me say that all the discourse really adds to the knowledge base.
Old 06-11-2017, 11:36 AM   #13
1977 Argosy 28
Fallon , Nevada
Airstream-specific or general utility trailer?
It's good to remember Dexter makes axles to supply to many OEMs: horse trailers, utility trailers, car carriers, etc. Dexter can not specify the correct shocks or geometry for Joe Bloe building utility trailers in his barn. That's up to Joe Bloe. Very many manufacturers don't bother with shocks at all. My Holt car carrier is one. Would the Holt handle better with shocks? I'm certain it would. I attempted to figure out some practical way to add shocks but I failed.
Does the Dexter damp oscillations better than the plain old multi-leaf springs on the Holt? I'm certain they do. Multi-leaf springs depend on the friction - static and dynamic - between leaves for damping; it works but not well.
Is the Holt user likely to be as fussy and demanding as the Airstream user? <Exercise for the student. >
So Airstream has gone to the extra work to engineer proper shock absorbers to the suspension.
There is compression damping and rebound damping. You want just enough compression damping to stop the wheel-tire-brake-suspension from continuing its ballistic arc upward when it hits a bump. You want most of the damping when the wheel is traveling back down. You'd like it to be *crticially damped* (engineering-physics talk; dampening is what you do to your Depends) but that's a moving target that depends on trailer weight and a dozen other factors.
So you're talking apples and apple seeds, here. A generic component part and the specific application.
Scorge-ION is offline   Reply With Quote
Old 06-11-2017, 12:02 PM   #14
Mollysdad's Avatar
The torsion axle provides spring.
Shocks help tame the spring so the wheels stay in contact with the road.
Many years ago, as a teen, my dad's car had bad shocks, so I thought, "Rather than listen to the clunking, I'll just take the bad shocks off."
Ha, the first stop had me bouncing up and down until I thought I'd get seasick.
Old 06-11-2017, 12:14 PM   #15
Boxite's Avatar
2008 22' Safari
Shock absorbers don't actually absorb shock. They prevent wheel "bounce". If you've ever driven down the road and seen another vehicle's tire bouncing like a basketball dribble... it's the shock absorber which has failed. Good shocks will keep the wheel on the pavement.... and improve braking thereby....as well as directional-control.
Torsion axles do not suffer from the same harmonics of spring-rate as other axles do, so they rarely need shock absorbers. If your trailer was designed with shock absorbers....keep them in good order and replace them when necessary.
If yours was designed without shock absorbers, it's unlikely you will benefit from adding them ...and may damage your trailer and/or suspension if adding them without the benefit of proper engineering support. Trial and error will likely prove expensive and maybe even damaging.
Old 06-12-2017, 03:50 PM   #16
Half a Rivet Short
2022 Interstate 24X
Hi
If we want to get very complicated about it, shock absorbers add damping to the system. They lower the Q (typically below 0.707) of the spring + mass. Their damping function acts for either extension or compression. Indeed the "how does it act" is why there are so many different shock absorbers. A spring + mass without a shock absorber would wobble back and forth for quite a while after energy is supplied by a bump. (They convert the energy to heat slowly). Shock absorbers speed up the energy to heat process.
Restoring Torsion Arm/Axle Resiliency Happycamper Axles 15 06-08-2018 06:12 AM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 04:37 PM
torsion axle questions nevisstudio Axles 2 09-01-2004 02:36 AM
torsion axle...not sure nevisstudio Axles 6 04-01-2004 09:40 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 08:41 PM
