Old 11-22-2018, 07:53 AM   #1
2018 28' Flying Cloud
Titusville , Florida
White shavings/dust
Does anyone have any idea what these white dust/shavings are from? Every time we take our 2018 FC 28RBQ, we find these white dust/shavings on the floor, only on the driver side. They are extremely fine shavings of something and they break into fine dust when you try to pick them up.
I simply cannot figure out where they are coming from.
ID:	328320   Click image for larger version
spark01 is offline   Reply With Quote
Old 11-22-2018, 07:55 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Post a photo
Old 11-22-2018, 08:05 AM   #3
kpm
2018 25' International
Mound , Minnesota
It is not uncommon for a new trailer to shake loose wood dust or shavings from cracks or joints when it is towed. I think they are byproducts of the construction process. Is the dust made of wood or plastic?
kpm is offline   Reply With Quote
Old 11-22-2018, 08:26 PM   #4
subfan1's Avatar
2019 23' International
La Habra , California
Our 2019 23CB generates the same wood shavings located to the left of the entrance door. I can’t find where it’s coming from
2019 GMC Sierra Denali
2019 23CB International
subfan1 is offline   Reply With Quote
Old 11-23-2018, 07:04 AM   #5
It's too white to be of wood. My guess is it's of some plastic material; these fine shavings easily break apart into powder/dust when I try to pick them up, and they don't dissolve in water.
At first, I thought they were from the Kleenex tissue box where you often find some pulp dust, but I have now eliminated that as a suspect.
Old 11-23-2018, 07:50 AM   #6
kpm
Mound , Minnesota
At any rate I'd wager you won't see it any more after a few more trips.
Old 11-23-2018, 09:21 AM   #7
1976 31' Sovereign
Oswego , Illinois
Styaform tends do this.
Old 11-23-2018, 09:29 AM   #8
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
If you look closely, you can see the spirals of white plastic drill swarf.
ALUMINUMINUM is offline   Reply With Quote
Old 11-23-2018, 11:15 AM   #9
2002 19' Bambi
Lafayette , California
+1
Tim
Tim A. is offline   Reply With Quote
Old 11-27-2018, 09:30 AM   #10
It has the same white color of Styrofoam, but the material breaks into powder rather than roll up like typical Styrofoam pieces.
Old 11-28-2018, 08:33 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
White shavings/dust
I’m going to tell you, dealing with construction dust is ALWAYS going to be a part owning an Airstream.
In spite of attempts at automation and component construction, for so long as an Airstream is built inside an aluminum shell with a narrow door, construction dust shaking out as we shake them down is going to be a part of the Airstream experience,,,,, so we may as well embrace it.
#GoodTimes
Dust Dust Dust Lumatic General Interior Topics 9 05-16-2016 08:35 AM
AC Ducts Blowing out white dust PSU1981 General Repair Forum 10 11-14-2015 04:11 PM
Warm-white vs cold-white LED lights? aircampr Airstream Lifestyle 64 03-13-2015 04:31 PM
White dust coming from vents in new '15 International ciparis Furnaces, Heaters, Fireplaces & Air Conditioning 7 09-17-2014 02:27 PM
Fine metal shavings appear while travelling bspelce 2006 - 2010 International 11 08-12-2011 07:07 AM
