02-03-2020, 05:24 PM
2016 30' Classic
Battle Ground
Where to buy new batteries? Battery Recommendations?
Hi,
You all told me on a previous thread that I probably need now batteries for my 2016 Classic. I've attached a side and top picture of what I currently have that came with the new As. Lifeline AGM deep cycle. Any recommendations on the best batteries to buy? Where to buy? My local RV repair guy (who I like so far) sells Interstate for about $150 each. I'm not too worried about price, just want something reliable and will last if I take care of them. Bryan Stewart
02-03-2020, 05:30 PM
GLCMRANGER - Sue
2016 25' International
Littlestown
, Pennsylvania
Before you buy ANY battery,,,,, upgrade that POS OEM Converter. I'd go with Lithium ION batteries,,, specifically Battleborn. Call Randy at www.bestconverter...... tell him you need a Progressive Dynamics Upgrade to accommodate Lithium ION charging profile.
There is a ton of threads on this forum.... read up!
02-03-2020, 05:36 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
You'll be hearing it, but you asked!
So many options. Just replace the AGMs you have, and take care of them. Switch to 6V golf cart batteries like Trojan T105s...more amp hours, true deep cycle. Good old Interstates, and replace them every year or two (unless you really baby them). Then sure, there's Lithium Ion...at $1,000 apiece--and generally a little more complicated as most people choose to relocate them to the interior of the trailer.
Hard to tell you what to do also without knowing your needs. Lots of power? Off the grid much, or mostly plugged in at campsites? Solar, if so, how many watts on the roof? Much inverter usage? And so on.
Maybe a description of your camping 'style' will help hone in the advice a bit.
Lastly, one of the best things you can do is install a full battery cutoff switch; or be sure to remove the positive battery wire when trailer is not in use; you didn't mention how you store your trailer, but if it's not plugged in or not on a trickle charger, and you just use the "use/disconnect" switch, you are constantly running your batteries down due phantom loads, which kills them quickly.
02-03-2020, 05:39 PM
2019 27' Globetrotter
McHenry
Bryan, the Interstates are likely not AGM batteries but flooded-acid. AGM's require no maintenance while flooded-acid require frequent checking and adding water.
Your Classic likely has solar since you've got the Lifeline batteries (part of the solar package). They are not cheap.
Before you toss them, you should consider having them professionally tested by a reputable battery shop. Contact Lifeline directly first and ask them for recommendations.
If you do need new batteries, Lifeline is one of the better AGM brands but I'm sure other posters will offer some options.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
02-03-2020, 06:21 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Your LifeLines have a 60 month prorated warranty. I would contact LifeLine Directly. You can ask to speak to Justin Godber
02-04-2020, 03:12 PM
2016 30' Classic
Battle Ground
Batteries
Thanks for the advice. Our style of camping: I store the Airstream inside a building on my property in WA State. It rarely gets below freezing, but I take the batteries out in the Winter and put them on a trickle charge. The storage building has no electricity, but I can get an extension cord up there if I want to. Our AS has a cut off switch for the batteries or storage switch. We take about six trip a year, maybe a third without hookups. Bryan
02-04-2020, 04:23 PM
1968 26' Overlander
CORDOVA
, TN
if you regularly run your batteries down, deep cycle is the way to go. .....It sounds to me like the problem a lot of people have is they are using a crappy low tech charger that cooks their batteries to death.....Those things are not expensive, and with a good one, you can leave your camper plugged in to power all the time, and they keep the batteries in perfect condition.
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
02-05-2020, 09:13 AM
I'm In
, Kentucky
My son and I have bought AGMs from Powerstride; good prices, quick ship. I bought a regular wet cell starting battery and it was a mess when it arrived and the battery was DOA. Powerstride refunded my money. Replace with Lifelines, same size as you have now.
https://www.powerstridebattery.com/
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
02-05-2020, 10:21 AM
2016 30' Classic
Battle Ground
Batteries
Thanks so much GMFL. I called Justin at Lifeline Batteries and he prorated the warranty and I have new batteries on the way. So easy!
02-05-2020, 11:04 AM
2014 25' Flying Cloud
Comox
, British Columbia
I have a similar storage situation so I purchased a 15W solar panel for trickle charging and mounted it outside and run the cable back inside to the trailer. Works great at keeping the batteries topped up in storage, even in the winter.
02-05-2020, 01:36 PM
Overkill Specialist
Dadeville
, Alabama
That’s great to hear.
What a concept. A company standing behind the product.
Congrats on the NEW Batteries.
Now let’s make sure you have a 4 stage charger and take care of them.
02-05-2020, 03:04 PM
2022 25' Flying Cloud
NCR
, Ontario
the new direction is lion battery
much more capacity.
longer life,
much lower weight/AH
goes down to 10% vs 50% capacity usage
google battle born
that is what we have been using for 2 years
02-05-2020, 04:33 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Good decision...treated correctly they WILL last and work very well. Ours lasted 11 Seasons.
The recommendations for a converter is a solid one.
This one is working well for us, won't break the bank and can be adjusted for Lithium if you decide to go that route down the road.
If your Classic battery compartments are the same as ours, (that stupid hinge lip that makes battery removal all but impossible).
This little mod should help...those Lifelines can be difficult.😂
Good Luck..
02-06-2020, 11:09 AM
2006 19' Safari SE
Tucson
I just replaced our two Lifeline AGM Batteries, GPL-24T (that is, Group 24)...I got 7.5 years out of the last set and 6 years out of the original set. They have served us very well. The BEST price I could fine was BestConverters.com...they were the same price I paid for them 7 years earlier (from a different local supplier who no longer around). We have done biz with them before when we upgraded our converter to a multi-stage, and way back when we bought our Pressure Pro Tire Presure Monitor System. They do charge shipping, but even with the shipping it was less than I could find anywhere else (even those offering free s shipping). It took 3 days to get the USPS Priority.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
02-12-2020, 10:00 AM
2021 25' Globetrotter
Little Rock
, Arkansas
duckdave
wdwessinger[at]me.com
WBCCI # 4127
2021 25' Globetrotter FT, 2006/07 Interstate
2010 GMC 2500HD Sierra Crew 4x Diesel
