08-04-2022, 06:35 PM
2016 26' Flying Cloud
Arlington
, Virginia
Where is it safe to drill into the belly pan?
I want to install two sewer hose carriers to the underside of a 2016 26U. (Actually 5"x5"x7 ft vinyl fence posts.) I plan to rivet an 18 inch long 2" inch x 3/16" aluminum plate to the belly pan and use sheet metal screws to attach the carriers to the aluminum plate.
Besides putting the rivets where the holes are for the current carrier, where is it safe to drill holes in the belly pan? I have looked at the 2016 Flying Cloud parts book and I can't find a diagram of where the fresh water tank lives.
Is there a space above the pan between the pan and the hoses/tanks? If I drill just through the belly pan with a drill bit stop set to just go through the belly pan, will that keep me from drilling into anything important?
Any other advice?
Jeff
08-04-2022, 08:19 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Well, your trailer likely has tank pans to hold the fresh tank and waste water tanks up. The tank pans are likely insulated with about an inch of insulation.
I just installed a sewer hose (stinky slinky) holder under our old 69 Globetrotter as there wasn't room for the hose in the bumper storage compartment. I used the two frame rails for the main brackets. There you can have a steel material for your fasteners and are safe to use. I also drilled into the center line of the trailer's belly pan for my third support. You will have propane lines attached to the belly pan under the trailer.
Generally speaking, other than the tanks, there isn't much on the other side of the belly pan aluminum. You can use your magnet to find the frame cross members which would give you a steel material for attaching your "fence post".
Others will chime in who know more about your particular year and model than I know.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
08-05-2022, 02:37 AM
1994 25' Excella
Waukesha
, Wisconsin
If you're making your own hose carriers then hopefully you can make them long enough to span the two frame rails. If so, just mount them to the frame rails to support it like David mentioned above.
Have you confirmed that your hose AND the fittings on both ends will fit in the proposed vinyl fence post?
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
08-05-2022, 03:33 PM
2001 16' Bambi
Albany
, NY
Two places.
NO
PLACE
08-06-2022, 11:02 AM
Hamilton
, Ontario
If I were me, I would order some new belly pan rivets, drill out the rivets on some of the pan and take a look at the area you want to drill into. There will be insulation in the way but a look is worth the effort, because if you it drill into something you are not going to be happy. If you have access to a borescope you can take a look with very little intrusion into the pan.
08-06-2022, 11:14 AM
2016 28' International
Trois-Rivieres
, Quebec
I agree, I wouldn't attach anything to the belly pan sheet metal. If you look at the rivet pattern you will see where the frame rails and cross members are. As Dave said, if you screw your fasteners to the frame rails you'll be OK.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
08-06-2022, 11:22 AM
Arlington
, Virginia
Thank you to everyone for the advice.
And yes, the vinyl is 5x5 inches square and holds the hoses both in length and width.
Jeff
08-06-2022, 11:26 AM
Washington
, Missouri
Originally Posted by 01bambi16
Two places.
NO
PLACE
2 /\ agreed for the most part
https://www.airforums.com/forums/f44...-160792-2.html Note post 24...1/2" at best between pan and tank, where present.
having almost finished with the petcock replacement this was a great thread and answered my where to be VERY careful when cutting.
WashMoBob
