Old 08-02-2021, 06:05 AM   #1
1975 31' Sovereign
Stanton , Nebraska
Where do I get this steel C channel?
Our project is just old enough I misremembering how it all goes back together so need a little help from the forum ! This was labeled as rear / part inside and part outside the cabin . The aluminum and steel portion look like they need replaced but not sure what to look up to replace the steel portion. The steel portion is a c channel w a tilted back section not sure my photos show that . Thanks all !
ID:	400910   Click image for larger version
ID:	400912   Click image for larger version
rhonda70 is offline   Reply With Quote
Old 08-02-2021, 10:49 AM   #2
1970 23' Safari
Marion , New York
That steel angle looks to be your rear hold down bracket. It holds the shell to the frame in the back. I took my old one to a local fabrication shop and they made new one for me. The angle is 102 degrees to match the angle of the outer skin in back where the bracket attaches.
DremStremer is offline   Reply With Quote
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 11 04-17-2019 05:20 PM
U channel or C Channel???? vintageracer Repairing/Replacing Floor &/or Frame 5 01-24-2016 06:49 AM
Please help....how to get wood flooring out from c channel tamvalleyman 1970-79 Tradewind 26 08-20-2015 04:57 PM
What's the best way to get to U channel when replacing a section? kramynot2000 Repairing/Replacing Floor &/or Frame 7 05-21-2007 12:08 PM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
