Old 07-10-2020, 01:09 PM   #1
1970 27' Overlander
Tryon , North Carolina
Wheelwells
Alright braintrust!
In the restoration process, I have replaced my wheelwells with the dual axle ones made of a black poly I believe. The restoration has an entire new floorplan and I was wondering that after the black poly ones are installed do you cover those with a plywood cover or box built over/around the poly ones? There will be cabinets built over the wheelwells. I was thinking in a blowout situation the tire would come right through the poly and nothing stopping the shredding tire from shredding everything inside.
I would love a photo or two and all opinions!
Thank you, thank you!
Al
69Silvrbelle is offline   Reply With Quote
Old 07-10-2020, 01:19 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
You could put a shaped metal cap (riveted aluminum) over the poly ones. I think they would take up less space than and be a bit more durable than plywood. However, in a catastrophic tire failure neither are going to be much help in protecting the contents of the cabinets over the wheel wells. It's more as a second layer of defense from moisture & debris if a small hole develops in the poly...
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 07-10-2020, 02:03 PM   #3
batman's Avatar
1964 22' Safari
modesto , California
69Silvrbelle,
I think it's a great idea to cover the inside of the wheel wells. My .02
In my 64 Safari the wheel wells are made of galvanized sheet metal that is pretty thick. However I still insulated and covered them with 3/8 ply and incorporated them into the cabinets, for example under the galley sink I made a shelf for storage and under the dinette is a covered shelf with power for 12v accessories, TV and phone jacks. Carry on!
-Dennis
ID:	372458   Click image for larger version
ID:	372460   Click image for larger version
batman is offline   Reply With Quote
Old 07-10-2020, 09:47 PM   #4
1970 25' Tradewind
1975 25' Tradewind
1949 18' Trailwind
Buninyong , Victoria
These were pretty easy to make, a bit of time went into the riveting though.
Disco Stu is offline   Reply With Quote
Old 07-11-2020, 10:46 AM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
Ha! I found a picture of ours (a single axle)...double layer metal with insulation between the layers - posted for additional ideas. They are original to our '56 Safari.
Shari
P.S. Yours are gorgeous Disco!
Old 07-12-2020, 07:06 PM   #6
batman's Avatar
1964 22' Safari
Now that's a wheel well! Beautiful work.
-Dennis
Old 07-13-2020, 01:50 AM   #7
1970 25' Tradewind
1975 25' Tradewind
1949 18' Trailwind
-Dennis
Thanks, we can't buy anything suitable in Australia so we must make our own.
Fender (wheelwells) split repair explore more General Repair Forum 0 08-19-2017 08:51 PM
cracked wheelwells Chas Wheel Wells 20 10-02-2007 09:22 AM
