Old 09-28-2019, 10:22 AM   #21
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Originally Posted by steilkurve View Post
Good point. I wondered about that. This and the favourable reviews of command strips are pointing me in that direction.
Hi
The thing that got me going on command strips is the "change your mind in a year or three" part of all this. With no "damage" anywhere, the command strips make that part easy.
Downsides of command strips:
1) If you try them on a curved surface they may or may not hold.
2) The plastic is indeed plastic. Bash it hard enough and it breaks. In high traffic areas, it only takes a couple impacts from a case of beer
3) They are white and not very elegant. They may or may not meet with approval from the interior decor police.
4) You want to put them on a smooth / clean surface. The "textured" aluminum in the kitchen can be a problem. We have had to redo two on that stuff.
Sitting here typing I can spot at least a dozen of them in our trailer. I'd guess there are over two dozen total in the trailer.
Downsides of screws:
1) They make a permanent hole
2) They really don't grip all that well in plywood.
3) The shorter they are the more likely they are to strip out.
Indeed your trailer (and mine) is fill of screws and they probably all are doing a fine job. As far as I know, all the screws in this trailer are doing great .... except for three of them ....
Old 09-28-2019, 03:07 PM   #22
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
There are some clear command strips and hooks. They do produce a few chrome looking plastic hooks... just in a limited number of sizes. Greasy areas, like.right next to the stove top need to be carefully cleaned!
Old 09-28-2019, 03:33 PM   #23
1976 31' Sovereign
Oswego , Illinois
Smile
3M also makes double side tape called golf grip tape it holds very strong, I use holding 2 pieces together when turning on lathe never had come apart when turning, after putty knife or small screw driver will separate, no residue on either piece.
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 11:18 PM
What type of screws (and what size) can I use in walls Maggiefoss Upholstery, Blinds, Walls & Interior Finishes 3 09-02-2011 06:28 AM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 05:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 08:20 PM
Clutch head screws Zed2 Windows & Screens 4 08-23-2002 06:16 PM
