RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-11-2020, 09:25 AM   #1
Essex , CT
What the power!!! 97 safari
Hello all I am having power issues and not sure where to look. Started with furnace and it was blowing but not lighting consistently. Ac and fridge consistently works. We are plugged into 30 amp. Changed the battery out and am noticing that the battery when on shore power is down to 10 v. It goes back up when I turn off an appliance and some lights after a while. I have a multimeter and checked yesterday after unplugging from shore the battery was at 11.5 v. I’m confused why there is a draw when connected to shore power? Especially when furnace is not working on fully functional battery.
AnAirstream is offline   Reply With Quote
Old 10-11-2020, 09:31 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Have you checked to make sure the converter is working? Has the breaker for it tripped? It sounds like your problem is in that area.
Old 10-11-2020, 11:13 AM   #3
richw46's Avatar
Lexington , Kentucky
What year is your AS?
Is your Use/Store switch in Use?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
richw46 is online now   Reply With Quote
Old 10-11-2020, 11:44 AM   #4
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
It sounds like your Convertor is not charging your 12v battery?
Full 12.6v
Charging 12.8v or greater
Discharging 12.5v or less
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement EZ-Lift WD with 2 Anti Sway Bars. previous tow vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L
Ultraclassic is offline   Reply With Quote
Old 10-12-2020, 07:38 AM   #5
Essex , CT
I agree is does sound like a converter issue. It is a 97 I am not sure if there is a switch that manually puts us on shore. What seems to be happening is we run off battery even when plugged in. The charger keeps working really hard to keep up and works on shore power. If we put a lot of needs on the battery it inevitably can’t keep up. Do you know if there is a switch?
Old 10-12-2020, 07:39 AM   #6
Essex , CT
I have a switch for the battery that turns it off this kills power to the entire as
Old 10-12-2020, 07:40 AM   #7
Essex , CT
Sorry and this is a 97 safari
Old 10-12-2020, 07:43 AM   #8
Essex , CT
Thanks Terry my converter must be flawed. Inverter isn’t tripped. I’m wondering if the converter should also bypass the battery into main system. If so there should be a manual switch......
Old 10-12-2020, 09:05 AM   #9
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Your battery 12 volt system runs all the lights, the fridge controls, the furnace controls, the Hot water heater controls, the A/C controls, as well as other systems in your trailer. If you have the original power converter in your trailer, the odds are it is "toast". Replace it with a 4 stage charge converter. I have replace many old Univolts with the Progressive Dynamics PD9245 with excellent results.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 10-12-2020, 09:45 AM   #10
richw46's Avatar
Do you have a Use/Store switch by the door?
Is it in Use position?
The converter won't charge your batteries unless it is in Use position when on shore power.
When on shore power your converter is supposed to provide the 12 volt DC power. This happens as soon as you plug into shore power. The light on the Use/Store switch panel should be RED, indicating the presence of 12 volt DC, regardless of the position of the switch.
Because converters were only 2 stage in early model AS it was possible to overcharge a battery, so the Use/Store switch allowed the converter to provide all the necessary 12 volt DC necessary and optionally recharge the batteries (Use position).
If the switch is in Use position but the batteries are not being recharged then your converter needs to be replaced with a 4-stage charger. If the light is not red when plugged into shore power and you have 12 volt DC lighting inside, only when the switch is in Use position, then same thing, the converter needs to be replaced. If you have totally drained the batteries and they won't hold a charge then you probably need to replace those as well.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-12-2020, 12:39 PM   #11
1988 32' Excella
Robbinsville , New Jersey
Some trailers from the 80s and 90s had a switch to shut off the converter 120v power. Some were between the door and front window, some were near the store/use switch.
EDIT; In the 80s and into the 90s, (not sure how long) the store/use was actually a manual battery disconnect switch near the batteries/converter.
Old 10-12-2020, 08:44 PM   #12
Essex , CT
Thanks for your input. There is a switch close to the door that powers the outlet that the converter is plugged into. I do not have a light. I know the converter is working because I hear a hum. When I turn it off, there is no power to the trailer once batteries are drained. I think the converter is probably on the fritz!
Old 10-12-2020, 08:46 PM   #13
Essex , CT
yes you are right, there is a store or manual shut off near the battery. We also have a switch near the door that controls the converter. It seems to me that when we are plugged in, the converter should be powering the entire trailer and charging the battery. Thus, why our converter probably needs to be replaced.
Old 10-12-2020, 09:42 PM   #14
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
I have the same trailer.
Good, you found the switch that turns off the converter. I labeled it “ALWAYS ON” because I can’t think of a time to have it off. I stretched a piece of Velcro across the switch plate (it grips quite nicely to the mouse fur) to preclude accidental switch off when fiddling with the curtains.
Most owners of that year model have replaced the converter with a modern 3 or 4 stage . They are lighter, quieter and won’t boil your batteries if left on shore power for extended times...hey. Maybe that’s what the switch is far...
The changeover is easy and there are threads suggesting models and a very capable vendor who is a member of the forum.
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 10-13-2020, 05:51 AM   #15
Essex , CT
ugh the mouse furr! Great idea with labeling the switch because I have no idea what is up and down most days. I will look for a new converter, which seems easy enough. Once that is in, I think I should be able to have consistent power running through the battery and converter. Do you think I should be considering a converter/ inverter combo? I went to your blog, looks like some fun adventures and very similar airstream!
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 10:51 AM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 12:52 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 09:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 09:23 AM
