Old 02-24-2024, 10:00 AM   #1
1976 Argosy 28
Sherman Oaks , California
What is this tube? 76 Argosy
Renovating 76 center bath Argosy 28' I've been trying to no avail figure out what this pipe is. It wasn't connected to anything at one end but seems like it's attached to something on the other side. A different pvc pipe vents up to the roof. Is this an original part left behind? The gray tank looks to be sitting on a sloped pan maybe for overflow and this tube snakes behind to an area I can't see.
ID:	441340   Click image for larger version
Rachey is offline   Reply With Quote
Old 02-24-2024, 10:22 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
my 75 had a pipe like that attached to a fan with a switch mounted on a wall next to the toilet. It is the "fart fan"...
Richard
Old 02-24-2024, 05:40 PM   #3
Westcliffe , Colorado
It looks like it is probably the original heat hose going to the gray tank. My 75 24ft has the same thing. Black tank and gray tank both get some hot air.
JCRC is online now   Reply With Quote
Old 02-24-2024, 11:20 PM   #4
1980 24' Caravelle
vallejo , California
definitely heater hose to heat your belly tanks. kurt
ke6gkv is offline   Reply With Quote
Old 02-25-2024, 06:52 AM   #5
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
AS encloses the waste tank/s inside the belly skin, and there is usually a duct from the propane furnace that conducts hot air into the belly to keep the tanks from freezing. On my Bambi it disappears under the subfloor below the bathroom sink, and the return air is vented out of the subfloor under the refrigerator cabinet via a storage compartment with a false floor. When I was installing new vinyl flooring I first stuffed this vent with fiberglass insulation before I figured out what it did and removed the fiberglass. You appear to have something similar going on.
Aironius is offline   Reply With Quote
Old 02-25-2024, 09:22 AM   #6
1972 23' Safari
Phoenix , Arizona
This is the fart fan for sure! There is one in my "72 Safari. But I never use it, I don't FART! ha ha .
Lensman is offline   Reply With Quote
Old 02-25-2024, 10:27 AM   #7
geirws's Avatar
thats a hose that blows heat from your furnace to keep you water tank and water pipes from freezing
irwin
geirws is offline   Reply With Quote
Old 03-03-2024, 09:35 AM   #8
Ol Bob's Avatar
2006 34' Classic S/O
1994 28' Excella
1950 19' Globetrotter
Elgin , Texas
Auxillary hot air hose to push hot furnace air onto the tanks.
All The Best...
'Ol Bob
Ol Bob is offline   Reply With Quote
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 72 07-15-2020 02:07 PM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
Fresh water filler tube '63 Safari srgntpepper Fresh Water Systems 5 05-27-2004 07:16 AM
Tube type tires for 77 alum rims Mike B Tires 10 04-09-2003 08:04 PM
