Old 03-24-2017, 10:19 AM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
What is this?
There is this thin cable - which is actually a thin copper wire wrapped - that attaches to this cylinder piece that is mounted just under the front, street side banana wrap in my 1973 Safari. The wire went up into the trailer, but it has been too long since I took things apart, I do not remember where it went. Possibly to the umbilical cord. What is this? Do I still need it?
Note: in the picture, the banana wrap is off the trailer and is upside down
Greg
Name:	cable front street.jpg
Greg1410 is offline   Reply With Quote
Old 03-24-2017, 11:38 AM   #2
Trnpk Crsr's Avatar
Baltimore , Maryland
It looks like a temperature sensor. I suspect that it was for a long gone remote thermometer.
John
Trnpk Crsr is offline   Reply With Quote
Old 03-24-2017, 11:39 AM   #3
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
It looks like a sensor, perhaps for a weather station inside.
It's hard to tell from the picture, does the other side have a spot for a wire to continue or is it blunt?
Iansk is offline   Reply With Quote
Old 03-24-2017, 11:48 AM   #4
1973 23' Safari
1970 27' Overlander
Boerne , Texas
it did continue inside the trailer - but I had cut the wire. Not sure what was on the other end.
Old 03-24-2017, 12:14 PM   #5
Trnpk Crsr's Avatar
If you have cut the wire, the sensor is now useless. You can toss it.
John
Old 03-24-2017, 12:22 PM   #6
Trnpk Crsr's Avatar
Does your trailer have the weather station with the thermometer and (I think) a barometer? If the thermometer displayed both the inside and outside temperatures, the sensor in the picture measured the outside temperature.
John
Old 03-24-2017, 01:58 PM   #7
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Thanks everyone. A weather sensor makes sense.
Greg
Old 03-24-2017, 02:58 PM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
thats what it is.
It snakes up to the front end cap; mine was actually inside a piece of the black 1/2" plastic pipe, used as a conduit. (same stuff they use for irrigation lines in sprinkler systems, and also the Air Conditioner condensate drain line.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
