Originally Posted by LiLNomad
Hi, What glue/adhesive should I use in my 2007 Intl to reattach the black edging on the bathroom walls and kitchen? Im sure its something simple from Home Depot or Lowes but wanted to check first.
LilNomad
I have used contact cement to re-attach laminate before. I am guessing that is what the factory used (actually, a call to the Airstream service center might be a good idea as they will have a definitive answer for you, just a thought....). When I really want it to stay I will clean the previous glue with whatever solvent I have around (lacquer thinner, acetone) scuff the surface with some sandpaper and use West System Epoxy. Once attached with West the edging is going to stay. I avoid the 5 minute type epoxy's for this type of repair as they are just not the same.
If you decide to use West or something like it be careful as any that is not cleaned up immediately can be pretty permanent.
Bruce
