Old 04-02-2020, 07:14 AM   #1
Geogetown , Texas
Weird Water Problem
Need some help please...
Wife and I are hiding out in our airstream during all of the fun that is parked in an airplane hangar. We have full hookups, water, electric and septic.
This morning when I got up we had what looked like a fairly significant amount of water on the concrete floor (probably not as much as it looked like). After a couple minutes of panic I figured out that the fresh water tank was overflowing out onto the ground (concrete floor).
How would that be possible? We have shore water hooked up, and have for the last couple of weeks. The other day I checked the fresh water tank and it was at about 40%. This morning it was at 100% and leaking.
Has some sort of a check valve failed?
Any help/suggestions would be appreciated.
-Dan
Dweyant is offline   Reply With Quote
Old 04-02-2020, 07:22 AM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
There is a check valve in your water pump. It is stuck or leaking though. Basically take the front of the pump off to access it. Itís a spring loaded disc.
If you could have a superpower, what would it be?
I chose America
Bigventure is online now   Reply With Quote
Old 04-02-2020, 07:23 AM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The pump acts as a check valve so the water does not overfill the tank. You have a leak through the pump. Add a shut off tap in front of the pump or take out the pump and try to clean the seals or plug the line from the pump.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 04-02-2020, 08:08 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
No need to replace the pump here. You can get a rebuild kit and simply replace the diaphragm head. Get 2 when you order shipping in likely to be almost as much as the kit.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-02-2020, 08:26 AM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Any chance you are running the air conditioner, and the water is from your drain hose in the wheel well?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 04-02-2020, 08:39 AM   #6
Geogetown , Texas
Pat
I wish, it was 36 degrees last night, and this is WAY more water than that.
Thanks for the suggestions. Iíll see if I can order a rebuild kit (or two) today. Any suggestions on who to buy one from (if that is allowed).
-Dan
Old 04-02-2020, 09:03 AM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Dan,
Posting the pump make and model info might also help with specific directions.
IF it connects with a PEX fitting and nut to the water supply to trailer you might be able to disconnect and put a 1/2" plastic pipe plug, yup right up against the PEX rubber seal IF that's how it's connected. But this is an sofa SWAG as to your system.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 04-02-2020, 09:13 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
Before going drastic...disconnect city water, use the FW tank 'til it's low, hook-up and see if it stopped.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"My sex life is like a Ferrari...I don't have a Ferrari."
Dino Longuini
Tahawus....🌥
ROBERT CROSS is online now   Reply With Quote
Old 04-02-2020, 09:15 AM   #9
2019 25' Flying Cloud
Hendersonville , North Carolina
Water Pump Check Valve Failure
Before you go through the trouble of rebuilding the pump try this.
Turn off the fresh water supply to the AS. Turn the onboard water pump on and use up the water that is in the fresh water tank. The pump may clear out the check valve and perform fine. Sometimes a bit of dirt will cause the check valve to stick open allowing the onboard fresh water tank to slowly fill up.
Your check valve may indeed be bad, but this method worked for me one time on our 2017 23D. Never had another problem with it sticking. Good luck.
uraljohn is offline   Reply With Quote
Old 04-02-2020, 12:42 PM   #10
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
-Dan
Dan we have a 2009 classic. We have had the same problem in ours, just turn off city water and use electric pump for a few times. This resets the check valve in the system. Then go back to city water. Good as gold. If this doesnít fix, get access to pump and tap it the check valve may be hung up. If none of this trouble shooting fixes, replace pump. We yet to replace pump due to this problem.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 04-02-2020, 07:23 PM   #11
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
If using the pump doesnít clear you issue, the fresh tank just fills when you are connected to city water. You can just run off of tank and fill again for the time being if you canít make it to a dealer or perform the repair yourself.
We had this issue when we were under warranty. JC just replaced the pump. We did as others are recommending and the pump cleared and we were fine for about a month before it full on failed.
Best of luck. Keep us up to date with what you find out.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 04-04-2020, 04:09 PM   #12
Geogetown , Texas
Finished up the fresh water tank and hooked ups shore water.
So far so good on the tank staying empty. However I do have a little bit of water dripping around the road side tire well. No A/C or Heat running today so it canít be from that. Any ideas?
-Dan
Old 04-04-2020, 05:57 PM   #13
Greenjeans's Avatar
2020 16' Caravel
Garland , Texas
Also, might want to consider an in line water filter, after you get your problem solved, if you don't have one.
Eddie
Cosmic Turtle
2017 Tacoma
Greenjeans is offline   Reply With Quote
Old 04-04-2020, 06:06 PM   #14
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Happened to me when our Classic was less than 2 month old. Was the check valve and rather than repair the pump, the dealer just put a new one in and that addressed the issue. Obviously if it hadn't been in warranty, I'd try some of the solutions others have posted to you. Replacing the pump obviously will always fix the problem but is the more expensive route.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-05-2020, 06:05 AM   #15
-Dan
Around the dump valves?
Our grey tank valve flange was overtightened when installed, finally cracked two years ago.
ID:	364898   Click image for larger version
Molly Ivins
Dino Longuini
Tahawus....🌥
Old 04-05-2020, 05:19 PM   #16
Geogetown , Texas
Ok, a little more info.
The leak doesnít appear to be related to the grey water tank. Iíve had the grey water valve open all day (hooked to the septic drain) and not a drop of water on the concrete. That is running off the fresh water tank.
Last night when I tried to run off of the shore water, I was getting a very slow leak under the street side tire well.
So appears to be something related to the shore water. Any thoughts on what to look for?
-Dan
Old 04-05-2020, 07:30 PM   #17
2007 22' International CCD
Possible leaky low point drain valve?
rmkrum is online now   Reply With Quote
Old 04-06-2020, 04:54 AM   #18
2018 30' Classic
Can you take a picture of where itís leaking?
It only starts when you are pressurized from city water or when you fresh tank is full or filling?
BigSxyWhtGuy
Old 04-06-2020, 06:59 AM   #19
retired USA/USAF
2001 30' Excella
I got my rebuild kits through Amazon. Search Surflo parts and look for diaphragm kit. I see it going for $28 or so. It was much less when I got it. Must be getting popular
Roger in NJ
TAC - NJ 18
Old 04-06-2020, 08:31 AM   #20
knunut's Avatar
Chgo. N.W. Burb's , Illinois
Leak
Might be the inline pressure control valve ? (Limits City Water Press.) ) On my trailer it was inline near city hookup. All I had to do was snug up fittings. Might be difficult to get to.
knunut is offline   Reply With Quote
weird weird weird. 12v goes dark. click. wulfraat Batteries, Univolts, Converters & Inverters 8 10-10-2016 01:14 AM
Weird low voltage problem hhendrix Electrical - Systems, Generators, Batteries & Solar 6 09-01-2011 09:20 AM
Weird Tail Light Problem mello mike Lights - Interior & Exterior 8 06-24-2009 09:36 PM
Weird turn signal problem, maybe TV related AxelBruijnis Lights - Interior & Exterior 25 09-17-2008 03:28 PM
OK, Here's a weird water pressure problem mello mike Fresh Water Systems 8 01-08-2006 01:34 PM
