Old 07-09-2020, 01:40 PM   #1
1977 23' Safari
Sutter Creek , California
Water Pump - working, then no power? (1977 Safari 23')
Hi -
New to the Forums, and in my Airstream lifestyle, so please be gentle!
I'm living "off-grid" in a 1977 23' safari. The trailer has a solar panel on the roof to recharge the batteries. When I moved in (early May 2020), the water pump was working great, and I would simply turn it on at the control panel any time I needed to have running water for dishes or the lavatory, etc.
About 2 weeks ago I went to switch on the pump, and it didn't fire on. I checked the inline fuse (Bussman 20A), which was intact. I figured the pump was dead, so I ordered a replacement pump. Because the 2088 model was discontinued, I went with the Shureflo 4088 (12v DC, 3.0 gpm).
I replaced the pump, but it still will not turn on with the switch on the control panel. This makes me think there is an electrical issue somewhere else in the trailer, but I didn't notice any blown fuses in the fuse panel at the front of the trailer (behind the lounge).
I'm at a loss on where to go from here, and would appreciate any ideas. Is there another electrical panel I should check?
Any advice is much appreciated!
AWittyMan is offline   Reply With Quote
Old 07-09-2020, 07:59 PM   #2
2018 25' International
Slidell , Louisiana
there is a fuse or thermal breaker in the Power Center that the pump is on. It may be shared with other devices or lights. I do not have the manual or wiring diagrams.
it could also be the wall switch. Check those two items first.
Brian
BayouBiker is online now   Reply With Quote
Old 07-10-2020, 11:39 AM   #3
1977 23' Safari
I checked the fuse on the side of the control center and it is still intact. Is there a fuse panel behind the control center that I need to take apart the face of the panel to access?
By the "wall switch" do you mean the water pump switch on the face of the control panel?
Thanks again --
Old 07-10-2020, 12:38 PM   #4
Trnpk Crsr's Avatar
Baltimore , Maryland
Longer 70ís AS had two water pump switches: One on the control panel and one in the head. The switches controlled the water pump through a relay. I not sure, but I think the relay was mounted on or near the water pump. If you have a relay, it may no longer be working correctly.
Cheers,
John
Trnpk Crsr is offline   Reply With Quote
Old 07-10-2020, 01:35 PM   #5
Slidell , Louisiana
Again, I am not familiar with the wiring for these years. I would confirm there is no 12V power at the pump when the switch is on and also look for a relay as suggested. I was referring to the switch on the control panel and I would check for voltage and continuity across the switch. Not much else to suggest.
Brian
Shore power and gen power not working merrillv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-14-2019 09:46 AM
Will then heat pump switch over to the furnace? wsrb Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-30-2018 10:51 PM
Water Pump not working, power issue? Super Fam Water Heaters, Filters & Pumps 5 09-02-2018 05:38 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Dash Air Fan, Power window and Power Seat Stopped working alvinator Land Yacht/Legacy Motorhomes 3 07-13-2014 09:22 AM
