More likely an obstruction in the water heater mixing valve if you have one, or one of the winterization bypass valves in the vicinity of the water heater is not on all the way, or has picked up some sediment slowing flow.
Try 'exercising' the bypass valves by gently turning them on and off. That might clear up the problem (or, with my luck, make it worse).
