04-30-2018, 09:15 PM
2017 30' Flying Cloud
Cedar Park
Water pump is on - can't control water temperature in shower
On city water, with the water pump on, the shower is either full hot or full cold. The pump isn't consistently on, but control doesn't change whether I hear it operating.
When I turn the pump off, I get normal control of the shower temperature.
I have control of the water temperature in the sinks no problem.
Is this normal or do I have an issue?
Thank you
2017 Flying Cloud 30FB
04-30-2018, 09:37 PM
2017 30' International
Broomfield
Sounds like a defective mixing valve insert in the shower valve body.
04-30-2018, 09:47 PM
2011 27 FB International
Vancouver
, British Columbia
Why do you have the water pump on when you're on city water? The water pump is for water from the fresh water tank.
04-30-2018, 10:11 PM
1974 Argosy 26
Morrill
, Nebraska
If you shut the city water off and run the pump you will probably see normal operation as well.
Again! Why do you have the pump on when you are on city water?
05-01-2018, 06:09 AM
Registered User
2016 25' Flying Cloud
Fairfield
The other thing that might be happening is your outside shower is on but turned off by the check valve. Make sure the it is turned off at the fixtures.
Matti
05-01-2018, 11:58 AM
2019 27' Globetrotter
The Woodlands
We just had our mixing valve on 2017 23FB replaced under warranty. Either all hot or all cold, but much in between. Maybe they got a bad batch.
05-01-2018, 12:08 PM
2008 19' Bambi
2012 23' Flying Cloud
Bandera
Possibly the mixing valve directly on the water heater? That’s what I had to replace when I had the same problem.
05-01-2018, 12:10 PM
Retired paddler
1993 29' Excella
Brighton
, Ontario
[QUOTE=TG Twinkie;2095895
Again! Why do you have the pump on when you are on city water?[/QUOTE]
We’ve had to do that a couple of times in campgrounds that lacked water pressure, especially at peak times. Turning the pump on allowed it to make up the pressure for a shower or two in the morning.
Cathy and Hans
1993 Excella 29' w/Hensley
2011 GMC SIerra 2500HD SLT
05-01-2018, 01:31 PM
2018 28' Flying Cloud
Ammon
, Idaho
Thank you
Just curious why you are running the water pump when connected to shore water. I’ve aleays been told that’s a quick way to burn out the pump.
05-01-2018, 01:46 PM
Sag Harbor
, New York
Is the problem still happening? Would you please review the earlier replies, and update us with more details and answers to the questions raised.
Peter
05-01-2018, 02:23 PM
1987 32' Excella
Nepean
, Ontario
I had that same problem and a new cartridge in the shower valve fixed it. Just take the old one with you so they can match it up.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
05-01-2018, 02:32 PM
Sag Harbor
, New York
Did your situation depend on the variable of the pump being on and off, like the OP?
Ignoring the fact that it should usually not be necessary to turn on the pump in addition the city water, is the shower valve perhaps sensitive to excessive water pressure?
Peter
Thank you
05-01-2018, 10:06 PM
Cedar Park
Well I took a shower this morning without the pump on and had trouble getting the temperature right. This time around, it seems the water pump didn't make a difference.
My guess is the cartridge in the shower. I think I would have an issue with hot water at the sinks if it was a problem with the water heater or something else.
I will have the dealership take a look while they assess my tire blowout damage.
05-02-2018, 02:48 AM
Sag Harbor
, New York
Thanks for the update, sounds like a good plan!
Peter
06-24-2018, 09:42 AM
Cedar Park
So the dealership noted it wasn't worth a fight with Airstream over the shower cartridge, so I just replaced it now with a Danco from home depot - moen part number 1222. The removed Moen looked a bit crudy but not noticeably damaged, clogged etc. It seems to be working... Knock on wood.
I also replaced the shower head, which had cracked with a Camco - seems to work great and a ton cheaper than the Delta.
I will report back if I managed to screw it up.
06-24-2018, 10:03 AM
2005 25' International CCD
Westlake Village
Like others we replaced the stock shower mixing valve with a new due to it being physically stuck. But on one of our first trips still had whacky non-control of the shower temps. Mostly luke warm initially then “cold” flow.
Ultimately determined the simple mix valve at the water heater through storage door was not in closed position separating the cold and hot as it pushed through trailer. Had some ingnorant chilly showers until closing this bad boy !
Ah the fun learning these rigs.
06-25-2018, 10:45 AM
Opinionated newb...
2018 25' Flying Cloud
League City
, TX
Geez I need to check that on mine Vantair, same experience here and I thought warm was going to be par for the package!!
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
06-25-2018, 11:19 AM
2007 22' International CCD
Corona
A winterizing bypass valve on the water heater that is not quite fully closed will do weird things to water temperature...especially on the old setups that used three separate valves....
Another good way to have this issue is an outdoor shower that has the hot and cold valve open, and the showerhead turned off. That's another weird one to try to find...
06-25-2018, 06:53 PM
1987 32' Excella
Nepean
, Ontario
[QUOTE=marcesq;2119332]
I will report back if I managed to screw it up.[/QUOTchanged it to E]
You should have changed to an Oxygenics shower head.
VE3JDZ
AIR 12148
WBCCI 8080
06-27-2018, 08:16 PM
Cedar Park
Are you referring to the BodySpa?
Sent from my iPhone using Tapatalk
